? about transmission filter change
Old Mar 17, 2008 | 09:07 PM
rebelrick's Avatar
How many quarts of transmission fluid do you add after a transmission filter change in an '05 Dodge 2500 4x4?
Thanks,
Rick
Old Mar 18, 2008 | 08:03 AM
No Plugs's Avatar
I was curious about the same thing except on an 06 Ram 2500 4x4?
One source says 1 1/2 qts and another source says up to 4 qts???? Any help would be greatly appreciated.
Old Mar 18, 2008 | 09:58 AM
pik's Avatar
pik
In my '03 with a 48RE I had to put about 6 qts with a pan drop and filter change. Put in Mopar ATF+4 I found at Wal-mart.
Old Mar 18, 2008 | 10:06 AM
CamperAndy's Avatar
The book on the 48re says 4.1 quarts for a filter change but mine was just over 6. So buy 7 quarts and you should be covered. Just do not over fill it, add 4, warm it up then keep adding a little at a time till it is where it should be. You could also measure the amount of oil you drain.
Old Mar 18, 2008 | 12:15 PM
DBLR's Avatar
Dodge told me it would only take just over 4 qt's for my 06. After it was all said and done it took 6.5 qt's of trans fluid to bring it back to the full mark on the dip stick. BTW I used Amsoil ATF as its a full a synthetic trans fluid and it can take more heat then stock ATF.
JMHO
Old Mar 18, 2008 | 05:34 PM
reecegr's Avatar
my 05 took 6 quarts.
Old Mar 18, 2008 | 09:21 PM
dozer12216's Avatar
The answer lies in how good or bad the fluid drains from your tranny. Slight clearance variations allow for different amounts of fluild to drain from one tranny to another. Generally 4 - 6 quarts will catch most. Occasionally more will be required. Don't overfill and move shift lever slowly through gears and check in neutral, with engine idling.
Old Mar 19, 2008 | 11:18 AM
grandblanc's Avatar
JMHO
did you flush all the mopar oil out before adding the amsoil full-synthetic? correct me if i'm wrong, but the mopar atf-4 is not synthetic (petro oil) and i didn't think you could add synthetic to petro bassed oil.
Old Mar 19, 2008 | 11:24 AM
No Plugs's Avatar
I'm going with Amsoil ATF also when I change my tranny filter this weekend. I just looked on the back of the bottle and it says, "Compatible with petroleum fluids"
Old Mar 19, 2008 | 11:45 AM
DBLR's Avatar
No I did not flush out the Mopar trans fluid as it was still good, I did my first trans service at around 9K. I have put about 14K on the mixed trans fluid with out any problems. As No Plugs said Amsoil trans fluid is Compatible with all petroleum trans fluids.
Old Mar 19, 2008 | 01:32 PM
j-fox's Avatar
ATF+4 is a synthetic.
Old Mar 20, 2008 | 08:51 AM
DBLR's Avatar
ATF+4 is not synthetic its a group III fluid that is highly refined that is unless they have changed the ways its made in the last year.
Old Mar 20, 2008 | 10:22 AM
No Plugs's Avatar
DBLR - I'm not positive but I think it might depend on the manufacturer of the trans fluid. I see that Valvoline makes a full synthetic ATF-4 http://www.valvoline.com/pages/produ...asp?product=63
I'm not sure about Mopar ATF-4
Old Mar 20, 2008 | 01:52 PM
DBLR's Avatar
I've learned that some group III fluids and oils can be called synthetic even though they are not. To me synthetic fluids and oils are made from either group IV or V base stock not crude oil. After reading the Valvoline MSDS it states that it only meets Mopar spec 9602 not exceed it like a group IV or V synthetic would. So based on what I read one would think that its made from group III fluids and there for not a synthetic fluid, just highly refined dino oil that can be called synthetic thanks to some uninformed Judge in the Mobil/Castrol lawsuit many years ago.
JMHO
Old Apr 1, 2008 | 05:02 PM
high bid's Avatar
Although not a 3rd gen, I changed mine this past weekend. What a mess. I think it still needs a 6th quart and from what I learned the ATF+5 and above is considered synthetic fluid. You definately need more than the recommended 4 quarts!
