AAM925 front axle
Old May 7, 2004 | 11:41 AM
Jonbr's Avatar
Question AAM925 front axle
I am trying to find a manual locker for my front axle on my new Dodge 2500 4X4 AAM925. The last Dodge had a dana axle, this was no problem. It looks like ARB doesn't have a application for the AAM925 and OX locker doesn't either. Does anyone know if either of these companies are going to produce a locker for this application or if there is another company making a "Manual" locker for this axle? I don't want the problems that go with a automatic locker on the front axle.
2004.5 2500 std cab, milemarker winch, 2 inch lift, shell, on board air compressor, bush wacker fender flares.
Old May 7, 2004 | 08:51 PM
BADBOWTIE's Avatar
Not much help with the info you want. I have been looking into front axle upgrades as well. I have not found much. One shop told me that the ARB for the GM IFS 9.25 could be machined to work. I was not exactly comfortable with that idea. I hope someone else chimes in.
Jason
Old May 8, 2004 | 09:51 AM
RAMV's Avatar
ARB is working on one, should be released soon, I would contact them direct.... Also is very similar to the GM 9.25
Old May 8, 2004 | 08:40 PM
Jonbr's Avatar
Thumbs up
Thanks for the help. I had contacted ARB, and the guy I talked to didn't seem to think there was anything on the horizon for a manual locker from them. But I agree there is a reasonably good market from the new Dodge's and they are likely working on one. I have put in the compressor, guages and switches for the air locker, it will be ready when I can get the locker. I would prefer the ARB system because I have used them of my last several trucks and had no problems except the compressor. This time I have gone to a much more durable compressor. I can use it for pumping tires, running air tools, etc.
2004.5, 2500, 4X4, standard cab, long bed, 6 speed, winch, 2 inch lift
csramsey640
Jun 4, 2014 10:31 PM
rustydeeretech
17
May 21, 2011 03:05 PM
case310350
Jun 23, 2010 09:03 PM
Hawkeye
Apr 29, 2008 10:24 AM
Paul Winey
Jun 22, 2004 08:09 AM
