727 deep pan on a 48re?
Old Feb 5, 2006 | 09:39 AM
cjhauler's Avatar
Just was wondering if the pan configuration is the same. An aluminum deep pan for the 48re is around $200.00, however Summit has their pan, with 2 quart extra capacity on sale for $99. A great deal if it would work. Thanks
Old Feb 5, 2006 | 11:27 AM
dodgenstein's Avatar
It will bolt up, but 2 qts extra on a 727 is stock capacity for the OD trans.
Old Feb 5, 2006 | 12:27 PM
underwoodtransp's Avatar
yes copy that. I was told when I baught my double deep pan that it is just a 727 pan that will hold 4 quarts extra. Which means 2 quarts extra for a 47/48re.
Old Feb 5, 2006 | 12:33 PM
cjhauler's Avatar
Thanks, that was just the information I was looking for. I think I will just go ahead and get the PML pan.
Old Feb 5, 2006 | 02:33 PM
TexasCTD's Avatar
2 quarts extra? I was told that the Mag Hytec DD pan holds 4 quarts also over the stock 48RE tranny pan. So now I add 9 quarts of Tranny fluid instead of 5.
It is nice also to be able to drain the fluid from the pan before removing the pan to access the tranny filter.
Old Feb 6, 2006 | 09:28 PM
I have only been able to get 7 qts in my pan when I do a drain and drop. Maybe I am reading my stick wrong???
Old Feb 7, 2006 | 07:14 AM
spro2395's Avatar
Does summit make a 4 plus quart pan for the 727 ?
Joe
Old Feb 7, 2006 | 09:44 AM
scook6's Avatar
Do you have a part no.? I checked Summit's website and the cheapest I could find was one for $136.00.
Old Feb 7, 2006 | 10:06 AM
Mcmopar's Avatar
If you think that is a bad price, check a mag hy-tec
Old Sep 19, 2006 | 09:46 AM
ShaneCTD600's Avatar
Just a quick question. Is 5 quarts the stock capacity for the 48re? I just baught the Mag-hy-tec deep pan and wanted to know how much fluid to go buy. 9 quarts is for the double deep pan. So 7 for the deep? am I right?
EverydayDiesel
Nov 11, 2007 09:33 AM
KRB
Jan 28, 2007 04:54 AM
MrKen
Nov 23, 2006 03:19 PM
BigBlue
Sep 30, 2005 08:27 AM
67HotRod
Mar 4, 2005 07:50 AM
