4X4 question
4X4 question
I have been looking at 3rd gen trucks and noticed some have a 4X4 switch on the dash instead of the lever on the floor. What is the difference between the 2 and is the dash mounted switch a problem?
06 mega w/ electronic - no issues
05 QC w/manual - no issues
97 f150 w/electronic - no issues
96 suburban w/manual - issues
95 nissan w/manual - no issues
93 ranger w/electronic - no issues
86 nissan w/manual - no issues
89 mazda w/manual - no issues
moral of the story; dont know but only the chebby gave me problems.
My last truck had the lever, and my new truck has the switch. I used to say that I would only have a manual transfer case. When I decided to buy a MegaCab, I learned that ALL MegaCab's have the electronic transfer case and you get the switch (I't because DCX runs duct for AC/Heating where the manual transfer case lever would be).
I got to tell you, the electric switch is really growing on me. I've heard of no one that had any problems with them.
That's usually an issue with teh auto tranny more so than a manual, and only after the truck gets some miles on it. At least, that's my experience.
[QUOTE=elkman12;1372522]problem with manul, to get into and out of low you need to shut the motor off. this way with both 4X4 trucks.
Out your tranny in Neutral and shift it while you're barely rolling. It will pop right in. Just make sure you're not going more than a couple mph.
Personally, I wanted the manual shifter because I know when it SAYS 4x4 it IS 4x4. It's possible to be stuck in the sand in 4x2, switch an electronic tcase to 4x4, and it won't be able to click in because things might be binding and there's nowhere to roll because of the stuck situation. This can also happen on pre '03 trucks with the vacuum disconnect on the front axle, even with a manual shifter. I'm glad I got the stick! Plus, my dash cubby is bigger. :P
