4x4 Indicator Light is Backwards
Old Nov 21, 2013 | 03:43 PM
DrewGzy's Avatar
Will try to keep this short:
Someone moved my truck by just throwing the transfer case in neutral and pushing the truck (not far just in the driveway).
I got in later to head home and it was in 2WD but the 4x4 indicator light was on. I played with it some and it is completely backwards right now. If I put the transfer case in 2WD it shows 4x4 on the dash. If I put in into 4x4 the light goes out!
This only started happening after the truck was moved.
Any suggestions?
Thanks!
Old Nov 21, 2013 | 08:15 PM
rockcrawler304's Avatar
Ummmm...... I got nothing
Maybe unhook the batteries for a few min? Or unhook the switch and try going from 4x4 to 4x2 a few times?
Old Nov 21, 2013 | 09:54 PM
jhenson's Avatar
^^^That was my thought too.....do you have a manual or auto t-case?
Old Nov 22, 2013 | 11:17 AM
Shorts's Avatar
I'd say it's time to prank your buddies back
Go ahead and disconnect the battery as the first troubleshoot. If that doesn't work, start tracing wires. I don't know what the sensor or switch looks like. Any chance the connection was intentional swapped to be opposite?
Old Nov 24, 2013 | 12:11 PM
DrewGzy's Avatar
Thanks for the help....
It's a manual T-case and for now I just unplugged the wires going to the switch. I'm assuming the switch itself got messed up and when I get a chance to pull it and fix it I will do so but for now I'm just happy that the light is off.
Nov 26, 2010 02:19 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
candndelivery
Dec 12, 2005 05:14 PM
RowJ
May 3, 2005 08:16 AM
Don A
Sep 7, 2004 10:10 PM
