4WD Disengagement
Old Feb 14, 2007 | 10:36 AM
3500lly's Avatar
4WD Disengagement
I have an 06 with the manual transfer case. When I set it back to 2WD it seems to take a while before the 4WD actually disengages. Is there any way to change this? I was riding with a coworker who has an 04 with the electronic controlled, his did the same thing.
Old Feb 14, 2007 | 10:06 PM
Its All Good's Avatar
Change your auto locking hubs to manual locking hubs. Kinda $$$.
Old Feb 14, 2007 | 10:14 PM
Raspy's Avatar
Changing the hubs will have nothing to do with it. It takes a while because there is a load on it. When you shift out of 4WD back off on the throttle then step on it again. If you are in a corner it might wait till you straighten out because of the corner induced difference in axle speeds. Just take all the load off the drivetrain and it will immediately come out.
Wetspirit
Old Feb 15, 2007 | 07:27 AM
stock03's Avatar
Doesn't backing up a few feet disengage the hubs? Works for me.
Old Feb 15, 2007 | 07:59 AM
njmaier's Avatar
Stock hubs are always locked...nothing to disengage.
chromegrill's Avatar
you don't have hubs...
the reason it takes a bit is because its under load. back out of the throttle, shift to 2wd, back on the throttle. same way when shifting to 4wd.
Old Feb 15, 2007 | 10:35 AM
ColdCase's Avatar
Under load either by throttle or driveline binding. If the load is from binding you just have to wait till the drive line unwinds. A few left and right turns or baking up perhaps.
Old Feb 15, 2007 | 03:39 PM
Timmer's Avatar
when i go in or out of 4wd (i have a 6-speed also, so this may not work for you) i push in the clutch, slect what i want on the t-case, let out the clutch with no go pedal, this kinda gives it a negative torque, then i give it just a little go pedal, for some posative torque. iv never had a problem with it taking any amount of time going into or out of 4wd.
Old Feb 15, 2007 | 08:07 PM
TurboTed's Avatar
Like they said- just let off the throttle and it goes out of 4X4.
Old Feb 15, 2007 | 08:14 PM
stock03's Avatar
Oh ok. I didn't know that. I thought thew were automatic hubs.
Old Feb 15, 2007 | 09:08 PM
06dually's Avatar
Mine comes out of 4x4 instantly...I know this because when I'm driving around town in 4x4, I always reach down and take it out when I turn a corner, and then after I'm straight again I put it back in. If I don't do this it will hop the front end around the corner.
Old Feb 16, 2007 | 12:33 AM
[QUOTE=3500lly;1356789]When I set it back to 2WD it seems to take a while before the 4WD actually disengages. Is there any way to change this?[QUOTE]
Now if your talking about the 4wd light on the dash going out after you shift it back into 2wd then yes take the load off, but if your talking about the actual hubs unlocking right away then like I said earlier you have to change from auto hubs to manual hubs...some members here has done the conversion, do a search on manual locking hubs.
Old Feb 16, 2007 | 01:40 PM
jkitterman's Avatar
2003 and up trucks do not have automatic or manual locking hubs. The only thing that engages and disengages is the transfer case.
wrangler04
Jul 17, 2007 11:00 PM
VikingDiesel
Competition / Pulls / OffRoad
Dec 29, 2006 07:17 PM
95black2615
Dec 20, 2006 06:37 PM
Bill Tomlinson
Apr 23, 2006 03:09 PM
1320
May 6, 2003 06:30 PM
