48re toast?
Old May 12, 2012 | 10:54 AM
mwheaty's Avatar
48re toast?
was experienceing some of the 1-2 shuttle shift, then pulling my trailer started to get some major slipping in what was first, wouldn't shift to second would just pop outta gear and rev until i let up then it would grab, give it some throttle and pops out and revs again, on a hill became very very pronounced only at slow speeds.
So bought a borg warner solenoid and transducer. Dropped the pan, fluid was very black, about 1/8inch of sludge on the magnet, changed the filter also. Put it back together and filled it up with fluid. dropped the rear cooler line to try and get it to flush some and started it up, nothing came out after 10 sec......shut it down and scratched my head. hooked the cooler line back up and fired it up, threw a code, low transmission fluid pressure, couldn't clear it.
went for a test drive and right off the bat knew something wasn't right. Almost felt like a second gear start but was just reving like crazy to get going, if i put my foot into it, it would go but not hook up at all. Couldn't hear or feel any shift points at all felt like i was on a snowmobile for how high it was reving and no shifting.
tried to manually bring it to first gear, no change, no change in second either doing exactly the same.
check engine light is on can't clear it.
Did something get plugged?
is it my TC?
why would nothing come out of the cooler line? was it cause the trans was cold?
what is my next step?
any help please
rebel102285
19
May 2, 2009 02:51 AM
fitzer
Dec 15, 2003 04:50 PM
Lightman
31
Nov 21, 2003 02:14 PM
goldenears
Jul 1, 2003 02:01 PM
Extreme Diesel
Dec 6, 2002 11:24 AM
