48re "Flare" in OD
48re "Flare" in OD
Hey guys, I need some help. I just put a Suncoast Valve body and a triple disk converter in my tranny along with an upgrade band strut and apply lever, 4 ring accumulator piston and oversized intermediate servo and billit cap. I dont think that it is slipping. It just seems like it goes into a passing gear of some kind that it never had before. It will jump about 300-400 rpm. Then when you let off the pedal it goes right back down like it went back to OD. Temps always run cool, never above 180 at highway speed and usually closer to 165 or 170. So I dont think it is a slip. It also wants to hunt when I have the cruise on and try to pull a hill like it wants to go to the "passing" gear and will sometimes but not others. Could it be a pressure problem? It is an early 04 so I have a kickdown cable and pressure adjustment screws on the VB. Any help would be great.
Possibly, but shouldnt the converter be locked all the time in OD? Plus, I would not think that it would or should be going in and out of lockup when I am just cruising down the road at 70. Please correct me if I am wrong, but even if it was just going into lockup the rpms should not go up should they?
The rpms goin up would indicate the converter unlocking. Im not sure why it would be going in and out of lockup on flat level ground at a steady speed. Maybe something in the VB is not right.
Let me clarify a little, it wont do it on level ground unless I get a real strong gust of head wind or something. Most of the time I notice it is when I go up grades or go to pass. It does not take much throttle to get it to do it either, like I said it will do it with the cruise on. What really gets me is that it did not do it as soon as I did the upgrades, it took a while for it to happen. I am not sure that the converter is unlocking. Should my tranny temps not go up significantly if the converter was unlocking and locking this much? Thanks for the help guys.
I adjusted the TV cable and the shifting change just as it should. I shifts a lot firmer and later in the rpm range but it will still flare up in OD like it is not locked or is unlocking. Any other ideas what it might be or am I just not getting it adjusted right. About where does it need to be set? More toward front or rear?
You have checked for codes, right?
You might want to wire in a TC lockup switch to verify the problem and for later uses also. Tap pin # 7 on the round trans control connector, run the wire to a switch, then run the other side of the switch thru a 33 ohm resistor and to ground.
You may want to try and reset apps. disconnect both batteries, let sit for 1/2hr. Reconnect batteries, turn key to on, no start, slow push the throttle to floor and release slowly. Only other thing I can think of is maybe the bands weren't adjusted properly, may need to be recheck. Check with suncoast valvebody could have an issue. Just some ideas for you. sry can't be better help.
Thanks for the options guys. I bought the VB used off this site and it work great when I put it in. This problem just started all at once. What inside the trans controls TC lockup? Is it in the solenoids in the pan? Could they be bad? It seems to lockup as it should in tow/haul. Thanks.
