47re
Old Aug 23, 2009 | 04:54 PM
dakotajam's Avatar
47re
Whats tells a 47re to shift in to overdrive.
The shift point has gotten strange, shifts to soon and bogs down or waits till 3rd gear winds out to 65 mph.
John
Old Aug 23, 2009 | 06:03 PM
no_6_oh_no's Avatar
OD shift is computer controlled on all these tranmissions. The parameters for wheel speed, output speed sensor, governor pressure, etc, need to be within the range for OD to engage.
Do you have any codes indicating problems?
Possible causes are OD solenoid problem, output speed sensor problem, gov pressure solenoid\transducer problem, ABS sensor problem, connection problems on the harness, scuffed trans control harness.
Old Aug 23, 2009 | 10:39 PM
efil4ynot's Avatar
The torque convertor on my 47RE has always locked up too soon when in OD. Pretty annoying b/c if I don't watch it, it pukes tons of smoke when rollikng into it around 50mph. Sorry I don't have any advice but I'm in the same boat.
Old Aug 25, 2009 | 09:50 PM
dakotajam's Avatar
Talked to a trans- man today he drove the truck and said it seemed like the solenoid/ transducer he changes them both because they work in tandom and it's had to isolate one from the other. will see in a few weeks. couldn't get me in untill after the trip to Gettysburg.
thanks for the replies.
John
thehemikid
Feb 25, 2021 12:45 PM
Munchies
Oct 19, 2006 06:09 AM
sshelly
Jan 16, 2003 06:29 PM
TON4FUN
Jan 6, 2003 08:31 AM
FireNhole
Dec 7, 2002 04:39 PM
