Is it a 47re in a 03 standard hp model?
Old Dec 14, 2005 | 04:39 PM
ataboy9026's Avatar
Which trans in my 03 non HO engine 4x4? A 47 or a 48? rh or re? Just curious if anyone knows or are there different models installed? how to identify?
Old Dec 14, 2005 | 04:44 PM
ck1's Avatar
ck1
i believe it is the build date of the truck....I have an SO Calif truck with a 47re that was built in oct 02 and I believe it was feb 03(I may be wrong!) that the 48re came into play...
cameron
Old Dec 14, 2005 | 05:32 PM
converteddzlr's Avatar
If it's an SO engine then it'll definitely be the 47RE. You can confirm this by looking on the label inside your glove compartment.
Ken
Old Dec 14, 2005 | 05:44 PM
lokin4deer's Avatar
Ken
My truck was built Jan 19th 2003 and it has the 48re and it is a SO. Your best bet is to take the VIN to the parts dept of your dealer and have them run a spec sheet on the truck 3 pages of everything your truck has.
Old Dec 14, 2005 | 05:55 PM
Dodgezilla's Avatar
If you have an HO/Auto you definitely have a 48RE. SOs came with 47RE until they were all used up and then they started coming with the 48RE.
Old Dec 14, 2005 | 08:45 PM
abc4yew's Avatar
Lokin4deer is correct I have an SO with a 48re transmission housing . ks
Old Dec 15, 2005 | 04:47 PM
ataboy9026's Avatar
The only thing my tag in glove box says is it is a 4 speed auto trans. There are code letters but how to Identify them?
Old Dec 15, 2005 | 06:17 PM
Hannibal's Avatar
If you stop by your service dept and ask for a build sheet for your truck's vin#, you'll get two or three sheets of everything your truck is made of. I got it on my '03. They didn't charge me for it and it only took a couple of minutes.
FWIW, my two 47RE's were trouble free except for a shorted governor pressure sensor/solenoid. Replaced under warranty. If you're running stock power and ATF+4, I wouldn't worry about it. The 47 is a good tranny.
Old Dec 16, 2005 | 10:53 AM
Fummins's Avatar
My previous truck was an '03 S.O. with a 48.
Old Dec 16, 2005 | 11:18 AM
Dodgezilla's Avatar
Please refer to my previous post......
All HO/autos had 48re's
Some SO/autos came w/ 47re's and some later ones had 48re's....
Old Dec 17, 2005 | 02:32 PM
Tundra Maggot's Avatar
ditto..
03 SO with 48re. Build date Jan 24 2003
Old Dec 17, 2005 | 04:07 PM
ataboy9026's Avatar
And how to identify? Are the trans pans different shapes? If it is a 47 will the pan look like my 95? is there any tag or plate on trans anywhere?
Old Dec 18, 2005 | 09:35 AM
INsIdious's Avatar
There was a post somewhere on here a while back concerning this. The poster said something about the number of wires on the plug in on the tranny. If memory serves me, i believe he said 3 wires on the harness was a 47 and 4 wires was a 48.
Old Dec 19, 2005 | 04:21 PM
shoot, I forget the code, but it is listed inside the glove box... one of the codes.
Old Dec 19, 2005 | 06:25 PM
bubba33's Avatar
look in the glove box DG8 is the 48RE
