-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   Is it a 47re in a 03 standard hp model? (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/47re-03-standard-hp-model-85827/)
ataboy9026 12-14-2005 04:39 PM
Which trans in my 03 non HO engine 4x4? A 47 or a 48? rh or re? Just curious if anyone knows or are there different models installed? how to identify?
ck1 12-14-2005 04:44 PM
i believe it is the build date of the truck....I have an SO Calif truck with a 47re that was built in oct 02 and I believe it was feb 03(I may be wrong!) that the 48re came into play...
cameron
converteddzlr 12-14-2005 05:32 PM
If it's an SO engine then it'll definitely be the 47RE. You can confirm this by looking on the label inside your glove compartment.
Ken
lokin4deer 12-14-2005 05:44 PM
Ken
[nonono] [nonono]
My truck was built Jan 19th 2003 and it has the 48re and it is a SO. Your best bet is to take the VIN to the parts dept of your dealer and have them run a spec sheet on the truck 3 pages of everything your truck has.
Dodgezilla 12-14-2005 05:55 PM
If you have an HO/Auto you definitely have a 48RE. SOs came with 47RE until they were all used up and then they started coming with the 48RE.
abc4yew 12-14-2005 08:45 PM
Lokin4deer is correct I have an SO with a 48re transmission housing :D . ks
ataboy9026 12-15-2005 04:47 PM
The only thing my tag in glove box says is it is a 4 speed auto trans. There are code letters but how to Identify them?
Hannibal 12-15-2005 06:17 PM
If you stop by your service dept and ask for a build sheet for your truck's vin#, you'll get two or three sheets of everything your truck is made of. I got it on my '03. They didn't charge me for it and it only took a couple of minutes.
FWIW, my two 47RE's were trouble free except for a shorted governor pressure sensor/solenoid. Replaced under warranty. If you're running stock power and ATF+4, I wouldn't worry about it. The 47 is a good tranny.
Fummins 12-16-2005 10:53 AM
My previous truck was an '03 S.O. with a 48.
Dodgezilla 12-16-2005 11:18 AM
Please refer to my previous post...... ;)
All HO/autos had 48re's
Some SO/autos came w/ 47re's and some later ones had 48re's....
Tundra Maggot 12-17-2005 02:32 PM
ditto..
03 SO with 48re. Build date Jan 24 2003
ataboy9026 12-17-2005 04:07 PM
And how to identify? Are the trans pans different shapes? If it is a 47 will the pan look like my 95? is there any tag or plate on trans anywhere?
INsIdious 12-18-2005 09:35 AM
There was a post somewhere on here a while back concerning this. The poster said something about the number of wires on the plug in on the tranny. If memory serves me, i believe he said 3 wires on the harness was a 47 and 4 wires was a 48.
Tundra Maggot 12-19-2005 04:21 PM
shoot, I forget the code, but it is listed inside the glove box... one of the codes.
bubba33 12-19-2005 06:25 PM
look in the glove box DG8 is the 48RE
