47/48re trans adjustments
Old Jul 30, 2008 | 08:06 PM
bigdave's Avatar
The service manual I have only shows the 47re transmission, are the adjustment and diagrams for the 47 and 48 the same? The manual is for 00to 06 trucks, that is way I ask. Thanks
Old Jul 31, 2008 | 09:02 AM
coparam4x4's Avatar
This is from my 06 manual:
ADJUSTMENT - BANDS
FRONT BAND
The front (kickdown) band adjusting screw is
located on the left side of the transmission case
above the manual valve and throttle valve levers.
(1) Raise vehicle.
(2) Loosen band adjusting screw locknut (Fig. 74).
Then back locknut off 3-5 turns. Be sure adjusting
screw turns freely in case. Apply lubricant to screw
threads if necessary.
(3) Tighten band adjusting screw to 8 N•m (72 in.
lbs.) torque with Inch Pound Torque Wrench
C-3380-A, a 3-in. extension and an appropriate
Torx™ socket.
CAUTION: If Adapter C-3705 is needed to reach the
adjusting screw, tighten the screw to only 5 N•m
(47-50 in. lbs.) torque.
(4) Back off front band adjusting screw 1-3/4 turns.
(5) Hold adjuster screw in position and tighten
locknut to 41 N•m (30 ft. lbs.) torque.
(6) Lower vehicle.
The Rear Band is inside:
REAR BAND
The transmission oil pan must be removed for
access to the rear band adjusting screw.
(1) Raise vehicle.
(2) Remove transmission oil pan and drain fluid.
(3) Loosen band adjusting screw locknut 5-6 turns.
Be sure adjusting screw turns freely in lever.
(4) Tighten adjusting screw to 8 N•m (72 in. lbs.)
torque (Fig. 75).
(5) Back off adjusting screw 3 turns.
(6) Hold adjusting screw in place and tighten locknut
to 34 N•m (25 ft. lbs.) torque.
(7) Position new gasket on oil pan and install pan
on transmission. Tighten pan bolts to 17 N•m (13 ft.
lbs.) torque.
(8) Lower vehicle and refill transmission with
Mopart ATF +4, Automatic Transmission fluid.
gasser76
Nov 29, 2014 01:06 PM
92smokin blacky
Jul 27, 2010 01:54 PM
JustRamIt91
May 23, 2010 01:06 PM
Dufrain
14
Aug 9, 2004 06:43 AM
Bluebird
Feb 11, 2003 03:29 PM
