4 lo ?
Old Dec 20, 2009 | 07:33 PM
BAD GRAVY's Avatar
4 lo ?
hello all just a question anyone having trouble with 4 lo ? seems mine was acting up today. it has electronic shift on dash ? just blinked and kept blinking... 4 hi works fine. thanks
Old Dec 20, 2009 | 07:51 PM
Topper's Avatar
Are ya tryin to put it in 4L in Neutral?
Old Dec 20, 2009 | 07:54 PM
BAD GRAVY's Avatar
no im turning the swith too the right 4 lo
Old Dec 20, 2009 | 09:05 PM
2006Mega's Avatar
hes asking are you trying to put your truck in 4 lo while your transmission is in neutral.
Old Dec 20, 2009 | 09:22 PM
soulezoo's Avatar
DTR 1st Sergeant
If you are trying to put it into 4lo in any position except neutral, it doesn't work. If you are in neutral and getting the blinking, it is not shifting and you have another problem to solve.
Old Dec 21, 2009 | 05:46 AM
BAD GRAVY's Avatar
thanks too all but im leaving the trans in drive when i select 4lo.4hi is fine.
Old Dec 21, 2009 | 07:27 AM
ian515's Avatar
as they said above, it HAS to be in neutral. 4 HI works fine in gear, but 4 LO has to be out of gear.
Old Dec 21, 2009 | 07:36 AM
KWKING's Avatar
Actually,in neutral and ever so slightly rolling,slower than a walk,so that the gears can mesh.NO ROLL and it may not go in.Which leaves a blinking light.If that does not work then you most likely have a problem.It mentions rolling in the owners manual too.But rolling too fast will not work either,it needs to be slower than a walk for mine.
Old Dec 21, 2009 | 01:43 PM
Lost Lake's Avatar
There should be a book in your truck that tells you how to operate the truck. If I were you, I'd read it. Seriously. You're lucky you didn't tear your transfer case apart.
Must be your first 4x4 because all of them are like this.
Old Dec 21, 2009 | 07:07 PM
BAD GRAVY's Avatar
thanks too all for your help.4lo works fine... now
Old Dec 21, 2009 | 10:20 PM
Lost Lake's Avatar
Glad you didn't tear something up.... I had an employee that tried ramming an older truck of mine into 4lo while he was driving.... The old shift on the floor, and from the other employee with him at the time, I guess he was really grinding gears.... After that it never wanted to stay in 4lo ever. Had to drive with my foot on the shifter.
