There should be a white production label stuck to the underside of the hood that has the trucks options on it, or on the inside of the glovebox like mentioned.
Did you look on or around the diff cover?? Or if you want jack your rear up and rotate the driveshaft and count how many times you turn the shaft till the tire does a complete rotation
