3rd gen differences
Old Dec 15, 2004 | 09:12 PM
bama's Avatar
3rd gen differences
hate to ask a long winded question,but what is the differences in the 03 and 04 motors?and im only talking with a 6 speed manual tranny.im looking at some used trucks and would like to know the differences and what to look for.thanks,bama
Old Dec 15, 2004 | 09:20 PM
HorseHauler's Avatar
03 has 2 options, the SO motor which was 250hp 460 tq and the HO which was 305 Hp and 555 tq. the early 04 all they had was the 305/555 motor and then in 04.5 the 600 motor came out.
Old Dec 16, 2004 | 12:29 AM
midwestdually's Avatar
look me up bro..i will tell you all you need to know
Old Dec 16, 2004 | 12:49 AM
SuperGewl's Avatar
Actually you are incorrect. The 03 had 3 motor options, the SO CA (235hp), SO (250hp), & the HO (305hp). The 04 had the same . The 04.5 only had one the HO (305hp), the 05 only had 2 the 305hp & the 310hp.
Old Dec 16, 2004 | 07:43 AM
Graphite600's Avatar
The 05's have 2 options, early early 05's may have the 325/600 engine, and current 05's have the 325/610 engine.
Old Dec 16, 2004 | 08:15 AM
J BODY's Avatar
04 up has better diagnostics.
Old Dec 16, 2004 | 02:50 PM
mikmaze's Avatar
and rumor has it if ya flash the tsb on a 600 motor to 18 037 004 you have a 610 torque motor
Old Dec 16, 2004 | 04:24 PM
Original Junior's Avatar
No cats on the 03's either. I don't think the cats came until the 04.5 600s. Also my 03 came with a 3 inch exhaust which I replaced. The 600s come with a full 4 incher. Check here to confirm this but I hear that the 555s run cooler on the EGT side but produce less boost than the 600s.
Old Dec 16, 2004 | 06:14 PM
bama's Avatar
thanks fellas,,,,,,,,,now back to shopping
Old Dec 16, 2004 | 06:23 PM
budsowner's Avatar
Actually the 04.5 has (325hp).
Old Dec 17, 2004 | 09:44 AM
roadrat's Avatar
The change from the 305 hp. 555 ft lb. to the 325 hp. 600 lb. was jan. 1/04, so if your not sure which 04 you are looking at check the sticker on the side of the valve cover, or the build date on the sticker on the drivers door.
rob
anonymous_1
13
Apr 30, 2020 04:29 PM
1qckdodge
Mar 5, 2007 09:53 AM
Russell_d
Feb 25, 2007 09:12 AM
Trebor
Mar 24, 2005 07:15 PM
