3.73 or 4.10
Old Nov 28, 2009 | 09:58 AM
Undertaker's Avatar
3.73 or 4.10
I have a 2007 Dodge Ram DRW 48re with 12,200 gvrw. How do I know if I have 3.73 or 4.10 gears?
Old Nov 28, 2009 | 10:28 AM
triton20x's Avatar
Try calling a local dealer parts dept. and give them your vin#. That can usually tell alot about the vehicle.
Old Nov 28, 2009 | 10:38 AM
92'1stGen's Avatar
Do you have the stock tires on it? What is you RPM at 70? 3.73's will put you at about just below 2k RPM at 70. 4.10's will put you at about 2150 rpm at 70.
Do you have the window sticker from the truck? If it isn't listed on the window sticker than you most likely have 3.73's.
Another solution is to jack up a rear wheel, put a chalk mark at the bottom of the tire, and a chalk mark on the drive shaft. Rotate the tire one complete rotation and count how many times the chalk mark on the drive shaft goes around. If it goes around about 3 & 3/4 turns than you have 3.73's. If it goes a little over 4 turns than you have 4.10's. Try calling the dealer first though, that's an easier solution to try first.
Old Nov 28, 2009 | 11:26 AM
djcheez's Avatar
look in the glovebox. should be a sticker that gives certain specs including rear end ratio
Old Nov 28, 2009 | 02:12 PM
dieselkan's Avatar
If you jack up one wheel only the drive shaft will turn only1.865 times for a 3.73 and 2.05 times for a 4.10 due to other wheel not turning.
Old Nov 28, 2009 | 10:23 PM
92'1stGen's Avatar
Well, jack the other side up to then.
Old Nov 28, 2009 | 10:32 PM
rockcrawler304's Avatar
Only if you have an open diff. If you have a locker or at least a tight limited slip, you just need to rotate the tire one time. Otherwise you need to rotate the tire two turns.
