3.42 Gears for Mega
Old Oct 18, 2007 | 01:35 PM
  #76
Mr.DieselMan's Avatar
Thumbs up Ok with OEM
I hear the OEM AAM stuff is rock solid and reliable! Interested in your thoughts.
Old Oct 18, 2007 | 03:25 PM
  #77
nitis's Avatar
my thought is that I want to hear from some of these people who have gone through with the change out and see how they like it.
Could it be possible to chand out part of the tranny to get the higher final drive that the new g56 s have?
Old Oct 19, 2007 | 07:18 AM
  #78
ColdCase's Avatar
"In pre-2007 pickups the front axle requires a new redesigned differential case along with new side and differential pinion gears"
Sounds like this may cost a few $$$$ ....
http://media.aam.com/index.php?s=43&item=601
Old Oct 19, 2007 | 08:16 AM
  #79
levigarrett76's Avatar
Has ANYONE else bought a new truck with these or swapped to these???
Old Oct 19, 2007 | 11:17 AM
  #80
realsquash's Avatar
Ring gear spacer works...
Andy
Old Oct 23, 2007 | 09:54 PM
  #81
Shepherd57's Avatar
Are you saying that a new housing is not required just a spacer please explain
Old Oct 24, 2007 | 05:21 AM
  #82
Mark Hodowanec's Avatar
Andy
Are you sure? Will there be enough surface on the carrier to adequately pilot the ring gear? If so, what you say makes sense. If that's the case you would think that AAM would sell the spacer for guy's w/ old carriers that want to get the 3.42.
Old Oct 24, 2007 | 06:00 AM
  #83
new carriers generally are not that expensive... at least the dana 44 and 60 carriers i have bought in the past weren't...usually less than 100 bucks
if a new carrier is needed, i generally use it as an opportunity to upgrade to a limited slip or locker
Old Oct 24, 2007 | 08:01 AM
  #84
realsquash's Avatar
That's correct, a spacer is available and would work fine.
Andy
Old Oct 24, 2007 | 10:59 AM
  #85
redeyedracer's Avatar
Im pretty sure squash is right about the spacer, however ring gear spacers have been used for years as a bandaid fix instead of actually installing the proper carrier.
I agree that for most users the ring spacer would hold up fine, but alot of people in here are running 900++++lb/ft and doing 4x4 boost launches at the drags....I'm suprised the stock R&P holds up so well to that kind of abuse, but there in no way the 3.42's with a spacer will hold up in the front under high torque conditions. Like Levi said, use it as an excuse to get a LSD or locker.....just think 3.42 with LSD's F&R....heck while ur at it might as well throw in the wheelbearing/hub kit...
Old Oct 24, 2007 | 04:49 PM
  #86
realsquash's Avatar
It will hold up just fine.
Andy
Old Oct 24, 2007 | 07:12 PM
  #87
Shepherd57's Avatar
Can the speedometer be reset on the 03 to 06 trucks to read correct miles per hour.
Any updates from MLB 1 on fuel mileage
Old Oct 24, 2007 | 07:20 PM
  #88
nitis's Avatar
the gear change wont affect the speedo it reads from the abs deals or something like that any way it dont matter
Old Oct 24, 2007 | 07:47 PM
  #89
scootertrash35's Avatar
I think we need a search party to find MLB 1,i wanna know the mpg before i get the 3.42s
Old Oct 25, 2007 | 05:39 AM
  #90
The speed reads off of a tone ring that is on the differential carrier. A tone ring is similar an ABS ring. So, it does not not care about R&P ratio, but the computer needs to be adjusted if you cange tire size.
