295/70/17 tires without leveling kit?
315/70/17 tires without leveling kit?
Have a few miles left in my stockers but starting to take a look at whats going to be available to me. It is an 06 quad cab 4x4. Looking for some aggressive tread tires without having to lift and still be able to tow my fifth wheel. Jim
I'm had the NITTO Terra Grapplers 305/75/18's(I think that's what size they were) before I added my lift and new tires and I never had any problems. You should have plenty of clearance with the stock setup.
315s on stock rims may rub the control arm on full lock (a minor thing). A leveling kit does not help you here. 315s on H2 rims fit perfectly, no rub, and is probably the largest you can go without mods. Lots of info here on the forum, search for H2. I think 305s are the largest you can go on stock rims without any rubbing.
I have the 2" coil spacers and run the larger tires, without any problems. I have a very, very small rub on the control arm.
Here are BFG AT KO tires in the LT315 size, on the stock 17" rims:
Ebay has a good selection, as well as any 4x4 online shop.
Truck rides the same, no difference.
