2007 tie rods changed??
Old Sep 9, 2009 | 09:06 AM
Mindy's Avatar
So I have my truck at the dealer. He says that my tie rods are done ( which I knew) But because of my lift they cant put stock tie rods on it because dodge changed the way they make the tie rods since I bought my truck. And the new design wont work with my lift.
Sounds like a load of BS. This is his reasoning for having to use aftermarket parts and not stock parts and why it WONT be under warranty now.
Is there any truth to this at all...did Dodge change the tie rod since 2007?? Im so angry right now...
Old Sep 9, 2009 | 09:53 AM
RiverRat2's Avatar
Yes much of the steering linkage/parts upgraded in 2008,,,,,,, not certain about the Tie rod ends but it would not surprise me,,, let me make a few checks and get back to you
Old Sep 9, 2009 | 09:56 AM
Mindy's Avatar
So regardless of my lift or not...they wouldnt be able to use stock tie rods because they arent in production anymore right?
It should be under warranty...grrr!
Old Sep 9, 2009 | 10:43 AM
nutter3's Avatar
You changed the steering geometry when you did a lift kit. Dodge is no longer liable for any of your steering or front suspension components. You play-you pay.
Old Sep 9, 2009 | 03:11 PM
Mindy's Avatar
Well, my dealer has changed ujoints, a driveshaft, BOTH front axle joints and PS pump all since my mods. They have told me numerous times they fix ANY dodge part regardless of the mods.
My truck is a mall crawler...no playing in the mud.
Old Sep 9, 2009 | 04:51 PM
staarma's Avatar
Why not just pay for the aftermarket, read better than Dodge, parts and they cover the labor under warranty? This sounds much better in the long run anyway.
Old Sep 9, 2009 | 07:00 PM
Mindy's Avatar
They are putting Moog parts in. No choice anyway...Dodge doesnt make tie rods for my truck anymore ( well the early 5.9 07 anyway) This is what the dealer is telling me.
Yeah 1000. spent today.
Old Sep 9, 2009 | 09:02 PM
donhov's Avatar
No lift or suspension mods on my 07 5.9 and the dealer today just changed another tie rod part. About 3 months ago they did the upgrades tot he pitman arm and steering linkage including the steering shock, today during an oil change I was informed that they also needed to change an already changed tie rod part. Haven't been under yet but part was changed so yes parts are still available at least for the stock suspension
Old Sep 9, 2009 | 11:17 PM
WhiteMule's Avatar
I do not see why the new design steering set up would not work. I only have a 4"lift but it works great on mine.
Old Sep 10, 2009 | 07:57 AM
WildBill79's Avatar
I don't think the tie rods from the new steering design will bolt on to the old steering. Maybe that is what they are talking about. However, the new steering design will work with your lift. I have a 5" lift on my 05 and it bolted right in.
jkap
Aug 12, 2006 10:45 PM
Cowhand
Mar 17, 2004 03:31 PM
03quadduallyho
Feb 8, 2004 03:15 PM
Hoyt
Jan 18, 2004 01:02 PM
Lightman
16
Jan 11, 2004 02:04 PM
