2006 Replaced turbo and will not start
Old Sep 2, 2015 | 11:10 AM
Contractor's Avatar
Hi all. I swear I have searched high and low to isolate this issue but either I cant use the search very well or its not common. I replaced a blown turbo on our 2006 CR. It drove into the shop. Replaced turbo, and now It will not fire. Never opened up fuel system. Odd thing is when I turn the key on the grid heater relay clicks very rapidly and the SES light flashes just as fast. Also the security light is flashing. Im lost. Ive replaced these before and never seen this. Any advice would be appreciated.
Thanks in advance,
Contractor
Old Sep 2, 2015 | 03:43 PM
Contractor's Avatar
Turned out to be a bad ground at driver battery for PCM. Found a thread on this site describing my symptoms exactly but had to use google to fine it. Anyway fired right up
Old Sep 2, 2015 | 11:08 PM
BigIron70's Avatar
Cummins Guru
The old ECM ground will get you every time, glad you figured it out.
Sleigher
May 4, 2017 02:12 PM
ramlovingvet
Feb 9, 2011 10:14 PM
subspd
35
Mar 29, 2007 11:30 AM
DodgingTools
May 22, 2005 12:18 PM
