2006 3500 G56 clutch replacement
Old Aug 20, 2020 | 08:18 PM
realfast's Avatar
I bought this truck secondhand is there any way i can tell without removing the transmission if it still has the dual mass fly wheel? If it does still have the dual mass flywheel can i just replace the clutch disk and pressure plate or do i need to replace the flywheel to?
Old Sep 8, 2020 | 12:14 AM
robby t's Avatar
Yes 2006 g56 should have a dmf unless it's been changed out. You can tell if the dmf is still there if you still have stock hydralics, also if it is quiet at all times when you take off from a stop, & you can remove a cover plate opposite side of the starter two bolts & then you can see the flywheel, turn the motor & if you see small bolts as u turn it the dmf is there.
cvcook
Jun 12, 2013 10:08 PM
rich
Apr 30, 2008 11:16 PM
SmokinDodge12V
Apr 20, 2007 05:45 PM
98.5POS
Feb 15, 2007 07:20 PM
Rod meyer
Feb 5, 2005 10:14 AM
