2004 door locks
2004 door locks
I'm having an issue with my door locks, it just started the other day. When i unlock my truck (2004 4 door 3500) the drivers side back door will not lock or unlock with the remote or if i use the lock/unlock on the door. Has anyone else run into this issue? if so doe anyone have a fix for it?
thanks
Dave
thanks
Dave
my drivers side rear door does the same thing. turns out the wiring broke in the door hinge. common problem i am told and i havent found a fix for it besides replace the door harness. i don't want to do that. (pricey)
The wires get pinched and broken in the door jam, it's pretty common.
Just splice them together with some butt splices. I've done it a few times to other peoples trucks, never had a problem. I put the stock wire loom back on after I got done.
nomad65
Aug 20, 2007 06:01 PM
Bradtothebone
May 21, 2003 10:31 PM
