2003 California Dodge Ram SO Cummins-Worth buying?
I live in Southern California and am currently looking at purchasing a used truck.
With the HO not being available in early 2003 2500s, I know a lot of trucks purchased in California were delivered with the SO engine. Starting late 2003 the new engines passed smog and were shipped with the late 2003/2004 trucks.
When would it make sense to purchase a truck with the SO engine? Pricepoint?
How much should one deduct for the SO engine?
What improvements are available for the SO engine?
How does fuel mileage compare between stock HO and SO --unloaded?
I will have a large percentage of unloaded miles compared to towing miles and am curious if the SO engines do deliver better fuel economy.
I'm guessing there will be folks dumping the early "SO" truck to get the latest and greatest...I'm wondering if there might be a deal to be had.
Any help would be appreciated.
Thanks,
Carl
Thanks,
Carl
Welcome Aboard. Everything has a price. I wouldn't be worried on picking up an earlier SO in CA. Its not difficult to modify them to almost whatever HP level you'd like. There are tons of postings here doing just that. You do flirt with losing the warranty when you do that.
I think it would be a great idea to keep your eyes open for one, especially from one of those fellows who has to own the latest and greatest. Their loss is your gain.
If you can get a good deal on one, I say go for it. All the mods are available for these as well. You can easily add more HP than your tranny can handle. One thing to remember is that the 2002 HO's were 245 HP - not much more than a '03 California SO.
I recall someone mentioning that the CARB engine, CA SO, runs at a lower engine temperature in orer to reduce nitrogen oxides. It might be one reason why the oil change interval is still only 3750 mi for the severe duty cycle, compared to 7500 for the HO and I believe the 48 state SO. I also seem to recall someone mentioning that Cummins noted that the lower engine temperature will also result in longer engine life, which I think is a good thing, but engine life is also one of the most boring performance parameters :^)
Good trucks
I ordered a CA SO '03 in June of '02. Just passed the 31k mile mark with zero problems. I was going to trade it in for a new '04.5 CA HO, figuring that adding mods to the already more powerful truck makes more sense. Now I'm not so sure. Other than more frequent oil changes, I didn't feel too much difference between the two versions. My driving is 99% unloaded freeway driving, so towing doesn't really make the upgrade necessary for me. I think you're right though, a lot of folks will be jumping to the latest and greatest asap. I'd just rather not take the big hit in depreciation so soon.
However, that being said, given the choice I'd rather not have a half year production truck. Since they standardized on the 50 state 600 engine, that's the way I'd lean if I were to make another purchase. Some used '04s should be coming on the market soon enough. Hope this helps...
TP
TP
MY ram is a late model 2003 SO, after the mod's I could bring it up to stall and fry the tires.With a puter that is consistantly off by 3-2.5 mpg I hit a high of 25 mpg on my way to Arkansas and back and a trip average of 19.9 mpg. Fuel in neck each fillup and pencil & calculator used still for each check. Also my engine temp. has dropped 5-10 degrees depending on weather from when it was first picked up (all of 3 1/2 weeks). I'm running 3.73 gears.
My S.O tuirned a year last week and has 16k...ZERO mechanical probs...just Ac stuff...mine was built 10-02....47RE etc...pull a very heavy 5th wheel (15k) couple times a month in winter and and a 10k tt in summer...really no pulling issues in regards to power etc...I love my truck....dont think I would trade it in on a 600 as it really does the job well...BUT if I was looking for a truck i would lean on spending a little more cabbage to get the NEWEST you could get as diesel technology changes almost overnight
Cameron
Cameron
I think the CA SO trucks may actually run the same temp or hotter than the non CA trucks. I installed an oil temp guage in my truck recently and the oil is at 210 degrees running empty on the highay at 2150 RPM. Runs about 200 degrees around town. Can't wait to see what temps it will be in the summer towing!!
The CA trucks have a more retarded fuel injection timing. I think that's why they need more frequent oil changes. They also have a cat (smaller than the '04.5's).
A box that does timing and a 4" exhaust system will take care of those things. I'd say go for it if you can get a good deal on one.
Boyd.
Boyd.
Re: 2003 California Dodge Ram SO Cummins-Worth buying?
Thanks,
Carl
Thanks,
Carl
Don't forget to pay attention to your trans though. An auto will require a different valve body and torque converter to handle serious ponies and a manual will require a different clutch.
Don't panic, changes to the trans and clutch are only necessary after you go past a certain point. All reputable retailers of quality parts can advise you on that.
jlipskoc
Nov 3, 2010 02:20 PM
spikerat10
Jul 4, 2007 11:47 AM
Olli
0
Apr 1, 2007 12:34 PM
supranick750hp
28
Jun 17, 2006 09:09 AM
hipsi
Apr 27, 2005 12:15 PM
