2 Injectors, 1700 Dollars?
A family member has an 03 305/555 with 130,000 on it. Truck has been run stock all its life.
Anyway, he just blew 2 injectors and the dealer wants 1700 dollars to replace them. is that at all correct? Doesnt that seem a little steep?
injectors
I reccomend a 2 micron filter. I would take the truck to a shop that does only hp cummins work or at least knows how to fix the problem and not throw parts at it. Just an idea Jim
injectors
Originally Posted by MikeyB
For $1700 I wouldn't let the dealer even touch my truck. I would call Don M at Formula 1 for his new injectors and have a local diesel shop install them.
MikeyB
MikeyB
Originally Posted by jimk
I have heard not first hand that you have to have good injectors to start with and then change the tips or nozzles. That could be off but the injectors could be $$ by the time it is all said and done. Jim
MikeyB
Mike,
Don M is here on the DTR forums. He has some very nice injectors.
http://www.f1diesel.com/injectorsecho.html
MikeyB
MikeyB
Guys when you buy performance injectors for common rail motors you are just buying the high performance service to them.
You have to send in good cores to start with...hence the core charge.
If you have bad injectors then you need to get some good stock replacments before upgrading.
Correct. When I sent mine in he found one of them to be damaged from the high pressure of the old EZ box. I wonder what would have happened if he would not have been able to fix it???
04ctd
103
Jan 29, 2006 08:11 PM
