2 cycle oil as an additive?
It's all personal choice. If you don't want to run it - don't. I have and do run it with good results. It costs me an extra .50 to .75 per tank, and I am ok with that. I have seen no negatives at this point, and it is a noticable difference when it's in the tank. Much smoother and quieter.
I don't put in 1oz per gal., I use about 12 to 14 ozs for a complete fill. I don't run it down to E, so I don't need the full amount every fillup.
I have run many tanks with nothing added, and it runs fine. As I stated earlier, my truck is much quieter and smoother with the 2 stroke, so I will continue to use it.
I already said don't run it if you don't want to, just stop putting down people that do - unless you have some type of proof that 2 stroke is harmful. I did a bunch of research before trying it, and found nothing that shows it will cause any problems.
Guess I forgot the higher oil prices since I bought it last. Maybe it would cost me a $1 now, that's about half a tank. I don't let it drop more than that in the winter. So yeah, maybe I will have to spend a whole extra $2 on a fill up - ohhh nooo.
Do you wanna take the chance that the tanker driver puts in the correct amount of additive when he refills the tanks at your favorite fuel station? Not me. That's why I dump in about 8 ounces every 3 or 4 fill ups. Then I'll run a bottle of Redline fuel additive. And if I think I might be running the oil too rich, I'll just do a fill up with no oil to thin out what's already in the tank. Been doing this for years on my '06, and did the same for my former '03. Never had a problem dumping in 2 stroke.
The Lubricity is automatically added to the Diesel as it's loaded into the trucks by the terminal, not the driver.
I do a lot of pump work in the terminals and asked about the lubricity.
I am not trying to start an argument, so forgive me if I made and an incorrect statement.
I originally posted that I have no experience with a cat and I told the person that I was answering that he MIGHT NOT want to use it, not that he shouldn't. A cat can be clogged very easy with oil.
Today I learned first hand, that a 5.9 Cummins at work was just re-ringed and a cat was added to the vehicle. The cat was required to be cleaned by taking the temp of the cat to 750 degrees. The cleaning was supposed last for 4 weeks. It clogged in 4 days!!! This I am sure was from the motor oil that was getting past the rings before they run in or seated.
I still think that 2 stroke oil can be used with a cat if the vehicle is driven so that the temp of the exhast is kept high. If it is driven short distances and not worked hard, any oil can plug up a cat on a diesel. A cat must run hot to do its work.
Papaduck,
No problem on my end, thought you might know something I didn't. I do a lot of towing and the oil sure seems to make things run smoother/quieter and it got rid of some low RPM stuttering (maybe cleaner injectors?). I'm sure with the EGTs I get towing, the CAT see's lots of extended time over 750. Thanks for your insights.
The amount of 2 stroke being added for most of us is very small. I don't see any issues with a CAT unless you dump a ton in, or maybe after a couple hundred thousand miles. I don't know how many anti 2 stroke people ran Low Sulfer vs Ultra Low Sulfer, but I can tell you I noticed a difference when the switch was made. It was not a huge difference, but noticable. The engine made a little more noise, and I lost about a 1 mpg.
With all the testing that's been done the rule of thumb is 1oz to 1 gallon.
Oh ya our trucks run on #2 diesel OIL. If you have oil getting by the rings bad enough to clog the Cat you'll find you have a run away engine on your hands.
I don't have any hard feelings against anyone, just don't post up info you have no first hand experience of.
I used some TCW3 on my trip this weekend. I seemed to have gained about 2 mpg cruising at 70-75 mph over the whole trip. 500 miles each direction. Back loaded with a atv and bags, and my milage went up from what it normally runs. Was it the oil? I have no clue but what ever it was my mpg improved. And when I punch it I get less black smoke.
I have a back-pressure gauge and without it I would never have noticed, nor would my issues be noticed on a truck without an EB. I also noticed that my exhaust was much "stickier" when I went to clean the quarter panel.
I was only using 10oz per fillup, but my truck didn't like it.
Lots of people use 2 stroke with great effects, I still recommend it to all my 2nd gen buddies, but its not for my 3rd gen. And there are plenty of posts where 3rd gens didn't like it.
Most 3rd gens don't like a full 1oz per gal, thou some do... But most have found .5-.75 oz per gallon is optimal for mpg/noise/lube. I was running .28oz per gal when I had my issues.
