12 miles 20 minutes city driving and barely warmed up...
Old Nov 11, 2007 | 02:28 PM
jesse_jamz's Avatar
...is this normal with ambient temperature at 44F?
Temp gauge just within the normal bar and the upper raditor hose is cold - Thermostat housing warm.
5.9 quad automatic 3:73 and just 600 miles.
Old Nov 11, 2007 | 04:29 PM
RDM16CTD's Avatar
That sounds the same as mine, especially slow to warm up in city driving. I bought the winter front from Dodge - that helps alot, especially when it gets to the 30s and below.
Old Nov 11, 2007 | 04:47 PM
JRAPTOR04's Avatar
Thats normal, these things take forever to warm up in the cold if your just putzing around
Old Nov 11, 2007 | 04:53 PM
cad14man's Avatar
Well - if you think about it; you do have to bring 1100 lbs of cast iron, forged steel, and a few other alloy's that make up a CTD up to around 180 ~ 200 degree's F. So it is going to take some time to do so. These engine's loved to be worked hard, otherwise they run cool.
I have to drive about 12 miles @ 70 mph before mine is good and warm.
Old Nov 11, 2007 | 05:00 PM
jrussell's Avatar
Welcome to the wonderful world of Cummins!
Old Nov 11, 2007 | 05:10 PM
t-boe's Avatar
The winter cover helps.
Old Nov 12, 2007 | 08:18 AM
SSminnow's Avatar
It was @ 50* here the other morning, and I left my house, and drove almost 30 minutes through town before it started coming up to operating temp. Put it this way. If you just start your truck in teh mornign, and let it idle....it may NEVER come up to temp. I left my truck running about a hour one morning, and I came out, and it was still pegged on teh cold. So, yes, it is normal.
Old Nov 12, 2007 | 08:31 AM
jrussell's Avatar
Yeah, even in 90* temps it takes a good 15 minutes to warm up in the city.
Try driving down a long canyon road in winter temps. Your engine can be 210* at the top and it will cool down to 140 or less on the way down. Cold enough that the heater is blowing ice cold air.
Old Nov 12, 2007 | 10:51 AM
53 willys's Avatar
when I kick my PTO high idle on, my truck warms up FAST.
Old Nov 12, 2007 | 11:29 AM
doug duncan's Avatar
yu can buy the winter front from dodge parts link below
https://www.dodgeparts.com/product_i...oducts_id/1872
it fits behind the grill like a glove will warm up the truck in five miles of driving
Old Nov 12, 2007 | 11:39 AM
fordkiller43's Avatar
Every person i know with a cummins has the same issue with warming up. It takes me about 12 miles @ 70 to get my truck warmed up. )
Old Nov 12, 2007 | 04:06 PM
BlueDually's Avatar
mine warms up in about 1 mile, at highway speeds, when below freezing. Thanks Espar
Old Nov 12, 2007 | 07:54 PM
Hairy1's Avatar
From: Adirondacks of New York and Daytona Beach FL.
Warming
It's just normal.......as said before a lot of everything to warm up, iron, oil, fluid..........You can drive in a lower gear to keep up rpm's to help a little....but only after initial warm up
Old Nov 13, 2007 | 02:51 AM
SuperGewl's Avatar
It's a Cummins, ie long warm up time. Buy the winter front and plug it in at night. I have heat within 50 feet of my house. If you have an exhaust brake, use it. You will be amazed at how good they warm up the engine.
Old Nov 13, 2007 | 07:52 AM
ThatGuy34's Avatar
use the high idle, works good for me
