105 MPH, that's all?
Old Oct 13, 2008 | 07:00 PM
stroker101's Avatar
truck launchs' real nice but falls flat at 105MPH. what can i do to gain more speed?
also i have a Diablo Sport Power Puck coming but would like to recal my speedo. what do you guy;'s recommend?
thanks for all your help
Old Oct 13, 2008 | 07:04 PM
Nate-03 D's Avatar
Do you somehow have a speed limiter on there? It's probley defueling at that speed.
As far as a recalibration goes, I took mine to the dealer and they used their DRB scanner, I think it was. To recalibrate my tires.
Old Oct 13, 2008 | 07:05 PM
MikeyB's Avatar
I'm using the SMARTY programmer and the limiter is adjustable. Think I set mine to 130 mph.
MikeyB
Old Oct 13, 2008 | 07:25 PM
BIGDAN65's Avatar
SMARTY lets you adj speedometer limits and tire size
Old Oct 13, 2008 | 08:58 PM
rich's Avatar
i get 110 out of the 06 and did have the 03 up to 120. the 07 was the same way went to about 110 then ran out of rpm room before peddle, but never hit a flat spot
Old Oct 13, 2008 | 09:01 PM
stroker101's Avatar
not sure if the previous owner has set a "speed limiter" on this truck. but it stops excellerating right at 105 mph.
i might visit my local dodge dealer and ask if they can calibrate my speedo to my 35" tires. it's 5 mph off(according to my garmin gps) hmmm?
then the truck only goes to 100mph
Old Oct 13, 2008 | 09:16 PM
bob4x4's Avatar
The Smarty will allow you to decide what your top speed should be
We were doing more than your top speed on a Baja beach last week
Bob
Old Oct 13, 2008 | 10:11 PM
stroker101's Avatar
Bob
that's awesome! lol
Old Oct 14, 2008 | 10:43 AM
stroker101's Avatar
my local dealer says that the "speed limiter" can not be adjusted and that the "speedometer" reads the speed of the vehicle from a "tone" ring in the rear axle and can not be adjusted for 35" tires.
he would have to have an authorization from "dodge headquarters" to perform this work.
if he can't do any of this, why does he need auth. from dodge?
also, if i install a programmer to try and adjust the 2 inputs, they can detect that a programmer was used and possibly void any warranty.
is he givin' me a line of BS? lol
Old Oct 14, 2008 | 11:31 AM
Spitse's Avatar
I had my speedometer adjusted at the dealer. Get the specs from the tire Manufacture on how many revolution the tire makes in a mile. The dealer can put that into the computer (they told me at first they did not have the size in the system and said they could figure it out by measuring the circumference and dividing 5280 (feet per mile) by that number, but TOYO had that info in the website). My 285-75-17 were off. started off a mile or two then as I got faster I was almost 10 MPH off. Going 70 on the Truck was giving me 80 on GPS. Now my Truck is spot on.
Old Oct 14, 2008 | 12:36 PM
Power Ram 4X4's Avatar
The 06 and newer trucks do not have the option to program revolutions per mile. Only can program factory sizes in them.
Old Oct 14, 2008 | 01:49 PM
Spitse's Avatar
My Bad, Sorry.
Old Oct 14, 2008 | 01:55 PM
stroker101's Avatar
can the top speed be increased? thanks
Old Oct 14, 2008 | 03:08 PM
enafzige's Avatar
Smarty will raise the top speed.
Smarty TNT-R will raise rpm to 4,000 with supporting mods.
Larger tires.
Overdrive unit...Gear Vendors, Mitchell, etc
At 3200 rpm, my truck's at 145 mph. At 4,000 rpm its 180 mph.
--Eric
Old Oct 14, 2008 | 03:16 PM
SOhappy's Avatar
If you feel like you're hitting a limiter (defueling) just override it by turning your key like you're going to start the truck. Honest, it works.
BTW, my ittty-bitty SO has no trouble with 105+.
