06 5.9 fuel filter
Old Feb 17, 2008 | 05:35 PM
Dodge89W250's Avatar
06 5.9 fuel filter
how do you change the fuel filter? is it a screw in like a oil filter??? or like a gas motor fuel filter where take of the lines and put a hole new filter in??
Old Feb 17, 2008 | 05:48 PM
banyon's Avatar
Look on the drivers side under the hood. It`s about half way down on that side of the engine.The top is black I think. It takes an inch & 1\8 socket. Screw off the top & replace the fillter. There is a yellow lever to drain the fuel on the side. Put the top back on & crank it up. Check for leaks & thats it.
Old Feb 17, 2008 | 05:55 PM
amesff01's Avatar
Drain the fuel in the cup first, then if there is sediment in there it will drain out and hopefully not go past the filter when you are changing it. The filter is held on by plastic clips on the bottom of the cap. you have to depress a few to get the filter off. Pop your new one on and replace the cover o-ring and you should be ready to go. Oh yeah, some filter have an o-ring the size of a quarter on the bottom. Make sure it came out with the old filter if not attached.
Old Feb 18, 2008 | 12:28 PM
DBLR's Avatar
Make sure you use a good 7 micron or smaller rated fuel filter (like the Baldwin PF 7977 or Fleetguard Stratapore) as some places still sell the old 10 micron fuel filters. FYI Cummins stopped using 10 micron fuel filters back in June of 2006 and wants all CR engine to use 7 micron or smaller filter. If you use a filter other then the 2 listed above make sure its also a water separator and it can strip the water out of your fuel.
JMHO
Old Feb 18, 2008 | 12:58 PM
cgmorgan06's Avatar
there is a how-to write up on here somewhere, I just can't locate at the moment.
Old Feb 18, 2008 | 08:01 PM
HorseHauler's Avatar
Here ya go, I did this write up about a year or so ago.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
Lunyfringe
Jan 10, 2005 05:40 PM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
