06 2500 has 10.5 AAM?
Old Dec 20, 2005 | 08:53 AM
djbikeman's Avatar
The website specs the 10.5 AAM even after the Cummins option is checked, so I called Dodge to see if this was a mistake. They said that it was accurate.
You have to get the 3500 to get the 11.5 AAM with the Cummins now.
Can anyone verify that this is true or not?
Old Dec 20, 2005 | 09:23 AM
Herrin811's Avatar
my window sticker indicates 11.5"...You get a Cummins, you get 11.5" and 750 amp batteries
Old Dec 20, 2005 | 09:46 AM
BigBlue's Avatar
I'd like to see what a cummins could do to a 10.5" when it's got 30,000lbs behind it.
Old Dec 20, 2005 | 10:05 AM
rickkari0304's Avatar
My sticker said 11.5" as well.
Old Dec 20, 2005 | 10:15 AM
Lrdchaos's Avatar
Same here 11.5 I think it's a mistake on dodges part.
Old Dec 20, 2005 | 11:11 AM
djbikeman's Avatar
That's what I thought, and was hoping to find out. I have been shopping a new Megacab for about a month now, and I saw that this morning and got a little concerned.
I can't believe Dodge made a mistake
Old Dec 20, 2005 | 11:14 AM
fredbert's Avatar
I went through all this while researching my '05. It turned out that the 10.5" AAM axle is for heavy duty gassers only. All CTDs get the 11.5". I can't believe they still haven't fixed their website!
Old Dec 21, 2005 | 06:54 AM
markshop's Avatar
10.5 rear axel
My window sticker said 10.5 too. Is there a way of visually seeing the difference?
Old Dec 21, 2005 | 09:45 AM
djbikeman's Avatar
Go to www.yourcovers.com, and you can see examples of diff covers for each. They are both 14 bolt.
The 10.5 has a short flat section top and bottom. The 11.5 is more pointed top and bottom. Also, the ring gear is more centered in the 11.5 AAM.
Hope that helps
Old Dec 21, 2005 | 12:40 PM
markshop's Avatar
Hope that helps
Thanks it is a 11.5 aam
Old Dec 21, 2005 | 02:07 PM
1sttruck's Avatar
"My window sticker said 10.5 too."
I'd believe the window or glove box sticker over most things.
Old Dec 21, 2005 | 05:11 PM
staarma's Avatar
Actually your truck probably has the 10.5 since it's an SO. To my knowledge, all 5 speed SO's had the 10.5. What does your glove box sticker say?
Old Dec 21, 2005 | 05:57 PM
TopBanana's Avatar
I remember hearing somewhere that AAM is working on a 10.5 inch front axle.
it's most likely gonna be used in the 4500's & 5500's though
Old Dec 21, 2005 | 08:27 PM
1sttruck's Avatar
"Actually your truck probably has the 10.5 since it's an SO. To my knowledge, all 5 speed SO's had the 10.5. What does your glove box sticker say?"
The 2003 SO with autos had the 10.5, all the other diesels had the 11.5, like I do per the window and glove box sticker.
Old Dec 22, 2005 | 07:52 AM
bigdav160's Avatar
And to add to the confusion, my 2003 SO/48RE has the 11.5 gearset.
