05 wont start
Old Nov 6, 2011 | 07:51 PM
JLee's Avatar
05 wont start
05 ran fine last night 480 miles to the house went to fire it up this morning and nothing it will crank but won't even try to start I have fuel everywhere I can think to check I didn't gel and its getting plenty of fuel to the pump I just put a fass on a couple of months ago
Old Nov 7, 2011 | 05:42 AM
papaduck's Avatar
Welcome to the forum.
Just because it is a new pump doesn't mean that it did not fail.
Make sure that it is running and pumping fuel. The filter could be clogged and make sure that the fuel is not bio contaminated. If there is it can get passed the filter and will carmelize in the injectors from the heat and when the engine cools the injectors will stick. An open injector will cause a no start by not allowing the rail pressure to rise high enough for the ECM to fire the injectors.
Of course there could be other reasons for a no start but to low a rail pressure is the most common cause.
rustydeeretech
Jun 16, 2010 09:41 AM
CoolumConst
Oct 11, 2008 10:00 PM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
Desert Diesel
Dec 5, 2002 08:53 PM
