05 not starting
Old Mar 13, 2011 | 08:40 AM
NYSmoke's Avatar
Unhappy 05 not starting
'05 5.9 all stock except FASS fuel pump/filter system. 163,00 miles on truck. New injectors, injector pump and turbo @ 90,000, thanks to incompetant dealership staff. Truck has been running perfect and was parked Tuesday night, when I went to start it on Friday morning, it cranked over, but no fire. Noticed lift pump was not running. Volt gauge and fuel guage not responding to ignition key action. Spent yesterday trouble shooting. Found if I remove fuse #17 ( vis. fan) truck would start and idle like normal, but sluggish acceleration. Can put fuse in while running with no effect. Shut truck off though with fuse in and will not start until it is again removed. I have check the threads here regarding electrical issues, great info. but so far no luck for me. Any thoughts. Thanks.
Old Mar 13, 2011 | 02:42 PM
NYSmoke's Avatar
Update,
Internal short in fan clutch. Got to thank the guys at Just Ask.com. 15 mins. and I had the solution. Money well spent.
Old Mar 13, 2011 | 05:20 PM
stiesel's Avatar
thank you for the update. never know when someone will be searching for that same problem.
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
FORDNOMORE
Oct 31, 2003 04:02 PM
admin
16
Aug 17, 2003 10:07 AM
