'04 running kind of
Old Dec 18, 2007 | 09:35 AM
Cummins Freak's Avatar
'04 running kind of
MY buddy owns a stock 04 cummins 6-speed manual and its running rough. When he starts it in the mornings, it'll idle about at 450 or 500 rpms until it jumps to high idle at 1000. Then driving, it seems like it doesn't have all the power it used to, kinda lugs. when he slows down for intersections it will drop down to 450 to 500 rpms like its going to die, it has died a couple of times, so I'll step on it, rev it up and the rpms will then bounce between 500 and 900 and after while it'll even out back to 750. I changed my fuel filter about 4 days ago. I haven't check my fuel pressure yet. And I don't receive any codes on the dash either. Any suggestions? Bad injector, lift pump?
I just dont know I'm not a CR guy yet
Old Dec 18, 2007 | 09:44 AM
Spooler's Avatar
It could be a lift pump headed south. No fuel pressure gauge it is hard to tell. Has this trucks LP been upgraded to the in tank unit? Also, read this tread. Intermittent short may cause issues.
https://www.dieseltruckresource.com/...ad.php?t=81936
Old Dec 18, 2007 | 10:25 AM
no mods what so ever 100% stock 70,000miles
Old Dec 18, 2007 | 03:24 PM
Ram Guy's Avatar
I would think the LP would cause that to be kinda crapy across the board and maybe even worse at higher RPMs.What about a crank trigger problem?
Old Dec 18, 2007 | 04:42 PM
Spooler's Avatar
That is what above suggested reading is about. Has to do with shorted 5 volts on the camshaft position sensor. The possible short is on the High/Low pressure A/C switch on the high pressure line.
Old Dec 20, 2007 | 11:22 PM
Changed FCA and no help what so ever....on to the next thing
93-12Smoke
Mar 15, 2009 10:15 PM
black&blue
Feb 18, 2009 08:32 PM
Cummins Freak
Dec 18, 2007 12:25 PM
mx684
Mar 11, 2007 11:55 PM
Dieseldude4x4
Oct 16, 2002 05:55 PM
