'04 Fuel Filter...
Old Apr 8, 2005 | 04:24 PM
starbreaker666's Avatar
'04 Fuel Filter...
Search was disabled.
I am changing the fuel filter on my father '04 Cummins next weekend. The proccedure seems straight forward. I only want to make sure I do it right of course.. Do I need to drain out the water/seperator fuel out of the filter bowl first? Or just unscrew it and pull/plop a new one in? Thanks guys in advance.
Old Apr 8, 2005 | 05:06 PM
hoser's Avatar
just unscrew it and pull/plop a new one in......doesnt matter , cleaner this way, just have a look in the bowl for crud while its out.
Old Apr 8, 2005 | 08:38 PM
cp's Avatar
cp
If you don't drain it and clean it out, you will be starting the new filter out with whatever water/crud is in there....PLUS... IIRC, it will be free to get on the INSIDE of the filter whereas it was on the outside of the old one.
Old Apr 10, 2005 | 05:34 PM
J BODY's Avatar
Run hoser RUN!!!!
At work I have a hand pump suction gun. I use that to vac out the fuel and any contaminates at the bottom of the filter bowl. It then gets a brake clean bath and wiped out with a lint free rag.
Old Apr 10, 2005 | 11:49 PM
Nevada's Avatar
You will need a six-point 1-1/8" socket.
Old Apr 11, 2005 | 09:59 AM
t-15 firefighter's Avatar
DTR's Self Appointed Beer Advisor
Hope these pictures help.
Fuel Filter Housing
Fuel Filter Removed. Notice the small amount of dirt in the bottom of the canaster? This is why you drain the fuel and clean it with a lint free cloth.
Dirty Fuel Filter
Instructions that came with the Fuel Filter
New Fuel Filter
There you have it.
Britt
Old Apr 11, 2005 | 08:32 PM
cp's Avatar
cp
One thing missing on those instructions is how to start the engine after a fuel filter change.
BUMP the starter (don't let the engine start), then leave the key in the 'on' position. You'll hear an electric fuel pump running. When it stops, the fuel filter is full--you're ready to start the engine.
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
Lunyfringe
Jan 10, 2005 05:40 PM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
