04 cummins without egr??
Old Jun 16, 2003 | 05:27 PM
Chrisf's Avatar
Has anyone ordered the 04 without the egr engine?? I know Anything after Jan1 04 will have the egr..<br><br>
Old Jun 16, 2003 | 08:26 PM
Lightman's Avatar
Re:04 cummins without egr??
Is that for sure the cutoff ?
Old Jun 25, 2003 | 12:17 AM
deje's Avatar
according to the local ******* all 04s will have emmissions control devices
Old Jun 25, 2003 | 12:24 AM
Lightman's Avatar
The aftermarket guys or forum members are going to have to figure out how to remove the egr without a check engine light. For 'off road' use only of course... : ;D
Old Jun 25, 2003 | 01:34 AM
bish777's Avatar
What is an EGR? Why is this a bad thing? <br>thanks
Old Jun 25, 2003 | 03:34 PM
phox_mulder's Avatar
[quote author=bish777 link=board=20;threadid=15964;start=0#153092 date=1056522844]<br>What is an EGR? Why is this a bad thing? <br>thanks<br>[/quote]<br><br>Exhaust Gas Recirculation.<br><br>Bad due to turbo, oily buildup gets all over and clogs the intercooler.<br><br>One of them there environmental requirements, been on gas engines for years.<br><br><br>phox
Old Jun 25, 2003 | 06:12 PM
deje's Avatar
i dont know about diesel engines but every gas eng. vehicle produced after 96 has an egr monitoring system as well as the egr system itself making it expensive to not only disable the egr but to also &quot;fool&quot; the confuser into thinking the egr is working properly. not saying it cant be done only its going to get in your wallet.
Old Jun 25, 2003 | 06:16 PM
Lightman's Avatar
In VW TDI diesels, the combination of the EGR and CCV system cause horrible intake clogging. This is due to the high amount of sulfur and particulate matter in our crappy diesel fuel as compared to the european diesel that the engine is designed for. Folks have had their intakes clogged 95%, to the point the air hole was about the size of a nickel. Some have disabled the egr by replacing it with a straight pipe and blocking off the flow from the exhaust. The combat the check engine light, a simple vacuum switch(for the hose to connect to) and diode trick the ecu into thinking the egr is functional. I must point out, these types of mods are for off road use, tampering with your emissions equipment is illegal....
Old Jun 25, 2003 | 06:45 PM
cp's Avatar
cp
How does sulfur turn itself into carbon? Isn't it carbon that's clogging the intakes on the VW's?
Old Jun 25, 2003 | 06:56 PM
Lightman's Avatar
sulfur=soot and the oily fumes and mist from the ccv combine with the soot to form a hard carbon. Icky mess, I just had mine all apart last night cleaning it.
Old Jun 25, 2003 | 08:51 PM
deje's Avatar
the intake on an inline cummins &amp; a jetta are two totally different animals im not worried about passages clogging as much as a carbon rock holding the pintle of the egr open causing a lean condition . lean = heat , heat = :'( :'( the passages can be kept clean with proper warm up ,shut down times &amp; good maint . just a mech. of 16 yrs two cents
Old Jun 25, 2003 | 09:41 PM
Lightman's Avatar
When 2006 and ULSD roll around, the clogging problem will be minimized. Right now the limit of 500ppm of sulfur per gallon just makes too much soot.
Old Jun 26, 2003 | 06:02 PM
cp's Avatar
cp
[quote author=Lightman link=board=20;threadid=15964;start=0#153470 date=1056595279]<br>When 2006 and ULSD roll around, the clogging problem will be minimized. Right now the limit of 500ppm of sulfur per gallon just makes too much soot.<br>[/quote]<br><br>That still baffles me. 500ppm is .05%. That's five one hundreths of one percent max content of sulfur in #2; I understand most diesel is actually testing out quite a bit less than that, around 250-300ppm.<br><br>But the thing that really puzzles me is that unless I'm mistaken, soot is carbon. I am not aware of any process in which sulfur can be converted into carbon, leading me to the perhaps erroneous conclusion that low sulfur diesel isn't going to do a thing for the VW's intake clogging problem.
Old Jun 27, 2003 | 04:18 AM
dodgeram's Avatar
the egr system helps remove the soot from the exhaust so the TDI's have low soot output on their exhaust .........<br><br>problem is it's injected pre intercooler so the soot filled exhuast travels through the intercooler &amp; intake leaving behind small bits all the way ...........after a while it plugs up<br><br>on that note my mom has 230,000 km on her 97 jetta TDI and has had no problems yet, so I wouldn't worry about it too much ..........
Old Jun 27, 2003 | 02:30 PM
wizkid's Avatar
Not every car has an EGR vavle. <br><br>Corvettes don't have an EGR and 01 and 02 LS1 Camaro's/Trans Am's don't either.<br><br>They made the cam with enough overlap (i believe that is what they did) to take care of the problem. I know it all hinges on the cam grind. <br><br>I have a 99Z and just pulled mine off and reporgrammed the PCM to not throw the code and disable the EGR system.<br><br>ERic
