04.5 Loses power at 2500 RPM
Because if you have pressure while running the engine the assumption is you have the required flow. This assumption is normally true but he does not have a gauge to check his pressure while running. So the zero pressure flow test is the best option short of installing a gauge. 100% stock any pressure over zero should meet required fuel flow.
The original post is that above 2500rpm the truck falls flat.This is when fuel flow is critical especially in the taller gears.The cp-3 uses the cascade overflow valve to take inlet pump pressure and ramp it to 85lbs+.It has 3 functions,directing fuel to be further pressurized for injection,internal lubrication and return excess.If the inlet volume is not enough to meet this pressure the valve does not direct fuel for injection it simply maintains lubrication and return flow.This why the cp-3 has a much longer life span than say the vp-44,it will not allow the lubrication portion to be cut short.I'm not implying 100% that he has a fuel supply problem but it is the first and most simple thing to check and it is a very common issue with the filter mounted pumps.
Heres some good reading on the cp-3 if your interested.
http://www.cumminsforum.com/forum/3r...mp-system.html
kimber
Nov 16, 2012 05:23 PM
BIGBEN
Jan 14, 2008 08:53 PM
fishin fever
Feb 22, 2004 08:32 PM
