04.5 Loses power at 2500 RPM
Old Mar 4, 2009 | 03:00 PM
  #31
randallp84's Avatar
Thanks for the help, homewrecker. What I'm experiencing sounds extremely similar to what mj experienced so I'm hoping this will fix it. I did take the truck to the dealer about a year ago and they said they replaced the crossover tubes (I don't remember how many or which ones) and 2 injectors so maybe they didn't torque the tubes right. It won't cost me anything and it's fairly simple, so why not give it a shot, right? Unfortunately, it will probably have to wait till the weekend though.
Old Mar 4, 2009 | 03:01 PM
  #32
mj1044's Avatar
it is defintley worth trying. i wish someone would have advise me to try it. i fought mine way to long and wasted 750 bucks on it.
Old Mar 4, 2009 | 03:02 PM
  #33
randallp84's Avatar
Exactly. I try to learn from other people's mistakes.
Old Mar 4, 2009 | 03:09 PM
  #34
mj1044's Avatar
just talked to the mechanic and he said it was the injector tubes (crossover tubes)that they tighten....i could have done that myself if i had known. i do hope that takes care off it. does your milage go south when it is acting up? Mine did.
Old Mar 4, 2009 | 03:12 PM
  #35
randallp84's Avatar
Yeah it seems like my mileage does decrease when it runs crappy but I'm just going by the overhead. I wouldn't be able to tell from a hand calculation on this tank anyway considering all the revving to 2500 RPM and above that i've been doing for testing purposes.
Old Mar 4, 2009 | 03:17 PM
  #36
mj1044's Avatar
yep. thats what mine was showing too.
Old Mar 6, 2009 | 03:20 PM
  #37
03 ant a hemi's Avatar
Ho did you make out with your situation?
Old Mar 6, 2009 | 03:23 PM
  #38
randallp84's Avatar
Haven't had a chance to tighten the crossover tubes yet. I will work on it tomorrow and we'll see if the problem is cured. I've got my fingers crossed.
Old Mar 9, 2009 | 12:55 PM
  #39
randallp84's Avatar
Ok, tightened the tubes and no change. Anybody know of a quick and simple way to check lift pump pressure? I'm now thinking that this could be the culprit because it did buck a little this morning in 4th gear at high RPMs. Not much, just barely enough to notice. Is that a sign of a failing lift pump?
Old Mar 9, 2009 | 01:10 PM
  #40
mj1044's Avatar
sorry it didnt work for you. was any loose. that was hopeing for a esay fix.
Old Mar 9, 2009 | 01:12 PM
  #41
randallp84's Avatar
I didn't put a torque wrench on any of them, just tightened them all. I turned all of them less than 1/4 turn.
Old Mar 9, 2009 | 01:18 PM
  #42
mj1044's Avatar
wished that would have worked. i bet it is the lift pump then.to put a stock one back on is a breeze. i dont know about the aftermarkety ones.
Old Mar 9, 2009 | 01:22 PM
  #43
randallp84's Avatar
Anybody know a quick and easy way to test the lift pump?
Old Mar 9, 2009 | 02:43 PM
  #44
mj1044's Avatar
were your fuel line goes from the FF to the cp3, i put a taped bango bolt in then i got one of those lights that tell you when the pressure drops below 5 psi. i wish i had just a gauage instead so i could see what it as doing all the time. i will end up doing that. it will tell you what the pressure is going in to the cp3.
Old Mar 9, 2009 | 03:26 PM
  #45
bradler's Avatar
man i hope you didn't do any damage, those connector tubes do not like to be overtightened...
Easy way to check lift pump = turn key on and listen for it to run.
Easy and cheap way to see if its flowing good fuel = take banjo bolt out of cp3 feed line from filter and put the line down in a bucket turn on key and see if its pumping fuel into bucket....
