04.5 drivetrain knock
04.5 drivetrain knock. poss 4x4?
I got a rotational knock under the front of my truck at low speeds. I thought it was a rotor but they seem Ok. I can hear it if i'm rolling slowly in heavy traffic but it seems to go as you get faster. Everything else on the truck seems to perform fine, i did 500 road miles today and it was fine except for this noise
If i engage/disengage the 4wd it stops for a while. There also seems to be an intermittent noise like some thing switching on and off under the truck.
I dont want to keep driving it an damage something as the parts are hard to get here in the UK and there is no dealer backup for truck.
Truck is an 04.5 3500 SRW QC 4x4 with low miles (45k) thats hardly been off road.
Thanks in advance for any answers
Andy
Andy
It kinda sounds like your U-Joints. In 2WD, drive slowly while turning real hard in one direction, then the other (stop to stop). The knocking may be more prominent when turning hard.
Mine was doing a similar thing and it was my axle u-joint. I am fiarly sure just looking and seeing rust and/or lots of particles around the joint was fairly obvious what my trouble was. My u-joints from transfer to front axle are still stock. Could one of these be failing on yours?
I have not heard of someone having trouble with the transfer case other than a couple racers that busted parts up.
I don't know who sells them on line, but there was a great thread with photos about how to replace ball joints. Since this involves removing the hub and axle, I thought it would be helpful.
https://www.dieseltruckresource.com/...ght=ball+joint
You may as well check the ball joints, since if they are getting a bit loose it would make sense to change them while it's apart. Also, put some anti-seize on the hub before you reinstall it.
Lastly, glad you found your problem, and that it isn't something too serious.
Motorama, how did you find out that it was the u-joints? I had a low speed knock like you described but my u-joints look fine. When my rear one went out, I could see wear around the rubber bushings over the bearing cups. My front ones appear to be fine.
We lifted up the front of the truck and got under there, you could hear them clicking when you spun the wheels and they dont look too pretty either.
Zee
Mar 23, 2010 09:54 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
