'04 or '04.5?
Old May 20, 2005 | 11:28 PM
TKC2000's Avatar
Question '04 or '04.5?
Being a new owner, I am not sure how to tell if my truck is an '04 or '04.5. I ask this 'cause I have seen aftermarket products specify the two. Also how can I check if I have the H.O. engine or not?
Old May 21, 2005 | 08:23 AM
HorseHauler's Avatar
check on the driver side valve cover. it will say advertised HP. if its an 04 HO it will be 305HP if its 04.5 it will be 325HP
Old May 21, 2005 | 03:11 PM
DR3500's Avatar
in '04 there is nothing but the 305 h.o. no more s.o.'s the '04.5's are 325
Old May 22, 2005 | 09:51 AM
STATELINE's Avatar
just look at the sticker on the drivers door. if manufactured 1-04 or later it's 04.5
Old May 22, 2005 | 11:16 AM
Ray Roton's Avatar
You could also check if it has a CAT.
No CAT on 04
04.5 and 05 have a CAT
Here's something that may help
2003 S.O. Federal Emissions: 250HP/460lb.ft. Available with NV4500 or 47RE
2003 S.O. Calif. Emissions: 235HP/460lb.ft. Available with NV4500 or 47RE
2003 H.O. Federal Emissions: 305HP/555lb.ft. Only available with NV5600
2003.5 The 47RE was replaced by the 48RE automatic transmission
2004 S.O. Calif. Emissions: 235HP/460lb.ft. Available with NV4500 or 48RE
2004 H.O. Federal Emissions: 305HP/555lb.ft. Available with either NV5600 or 48RE
2004.5 (50 state legal) 325HP/600lb.ft. Available with either the 48RE or NV5600
2005 (50 state legal) 325HP/610lb.ft. Available with either the 48RE or NV5600
2005.5 The NV5600 replaced with the G56 6spd manual gearbox.
Old May 25, 2005 | 09:51 PM
TKC2000's Avatar
HorseHauler------Thanx for the info. Checked it out the other day, sticker says it's the 325. I'm pretty sure it has the 48RE tranny.
Again, thanx for the tip.
Old May 26, 2005 | 07:42 AM
ramdez's Avatar
I'm planning on getting an 03 HO. How can I tell if its the 48re or NV5600? Will the door sticker say 03.5?
Old May 26, 2005 | 07:44 AM
ramdez's Avatar
It is auto. Does that switch my question to "do I have the 48re or 47re?"
Old May 26, 2005 | 08:22 AM
4X4 HULK's Avatar
If it a 04 HO you have a 48RE auto.
Old May 26, 2005 | 08:37 AM
ramdez's Avatar
03???
Old May 26, 2005 | 08:57 AM
4X4 HULK's Avatar
If its a HO it was the 48RE auto
