03 Tcase what/how much
Old Nov 8, 2008 | 11:26 PM
ratsun's Avatar
Hey guys, I want to change out the fluid in my Tcase on the 03 (nv5600 and electronic shift tcase) but I dont know what I put in or how much I need.
The dealer is ordering me a manual so.....I need to ask the experts.
I just did the diffs and the trans with the royal purple stuff ( my tranny really shifts nice now) but dont know what or how much goes in the tcase.
Old Nov 9, 2008 | 06:29 AM
JP-4.5's Avatar
See if this helps.....
File Type: pdf
Old Nov 9, 2008 | 10:10 AM
ratsun's Avatar
Thanks JP that does help allot!
I don't know if mine is a 243/273 (will look when it stops raining) but in either case I couldn't see and specific amounts, any idea on how much ATF+4 I need for either?
Old Nov 9, 2008 | 11:57 AM
Rough-n-Ready's Avatar
See if this info helps. This is out of an 03 service manual. I could not attach the pdf file for some reason. I just copied and pasted it.
AUTOMATIC TRANSMISSION
Service Fill - 46RE 3.8 L (4.0 qts.)
O-haul - 46RE 9-9.5L (19-20 pts.) L
Service Fill - 45RFE/
545RFE
4X2 - 5.2 L (11.0 pts.)
4X4 - 6.2 L (13.0 pts.)
O-haul - 45RFE/545RFE 14-16 L (29-33 pts.) L
L Dry fill capacity Depending on type and size of internal
cooler, length and inside diameter of cooler lines, or use of
an auxiliary cooler, these figures may vary. (Refer to 21 -
TRANSMISSION/TRANSAXLE/AUTOMATIC/FLUID -
STANDARD PROCEDURE)
MANUAL TRANSMISSION
NV3500 4X2 2.3 L (4.8 pts.)
NV3500 4X4 2.0 L (4.2 pts.)
NV4500 3.8 L (8.0 pts.)
NV5600 4.5 L (9.5 pts.)
TRANSFER CASE
NV241 GENII 1.6 L (3.4 pts.)
NV243 1.6 L (3.4 pts.)
NV271 1.89 L (4.0 pts.)
NV273 1.89 L (4.0 pts.)
FRONT AXLE ± .03 L (1 oz)
C205F 1.66 L (3.5 pts.)
9 1/4 AA 2.25 L (4.75 pts.)
REAR AXLE ± .03 L (1 oz)
9 1/4 2.32 L (4.9 pts.)***
10 1/2 AA 2.25 L (4.75 pts.)
11 1/2 AA 3.62 L (7.65 pts)
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip Additive.
** Includes 0.9L (1.0 qts.) for coolant reservoir.
*Nominal refill capacities are shown. A variation may be
observed from vehicle to vehicle due to manufacturing
tolerance and refill procedure.
Old Nov 9, 2008 | 03:07 PM
ratsun's Avatar
Excellent!
Thanks guys its a NV273hd
Bobcat698
18
Aug 3, 2006 09:23 PM
tacoma
Jul 13, 2006 10:49 AM
TRCM
Jan 11, 2006 08:50 PM
GO 4LO
Mar 18, 2005 07:49 AM
GO 4LO
Feb 12, 2004 01:42 PM
