03 Rough Idle
Old Sep 7, 2008 | 03:52 PM
ModManiac's Avatar
03 Rough Idle
Lately I have noticed my 03 has a rough idle, like a surge. I have ran injector cleaner through it but with no luck. The truck runs great but twice in the past month at lower rpms it had a miss but then picked up and ran fine. Its showing no codes and runs great but the surge at idle has me a little worried. I have herd of the 03-04 engines dropping valve seats, would adjusting the rockers show this? What are the common symptoms of injector failure, I have not noticed any diesel getting into the oil. Any help or suggestions are appreciated.
Old Sep 7, 2008 | 06:58 PM
rich's Avatar
sounds like the start of injector failure when it drops a valve you will know it sounds terrible been their done that. if it is getting hard to start or some smoke in the morning then i say injector for sure my 06 had a rough idle it was injector issue
Old Sep 7, 2008 | 08:22 PM
ModManiac's Avatar
I just reset it back to stock and it does fine but still has a little jump in rpm but not very often. I wish I had a rp gauge. Im going to buy a fca to see if it fixes the problem.
Old Sep 7, 2008 | 08:24 PM
FMB's Avatar
FMB
Originally Posted by ModManiac
. . . twice in the past month at lower rpms it had a miss but then picked up and ran fine.
Originally Posted by rich
sounds like the start of injector failure ...
That sounds like the beginning of the issues I had. It got worse over about 1,000 miles or so, and would set a code occasionally indicating a bad injector.
Gave it to the dealer at 97,500 miles and they replaced #1 injector, which by then, had stopped opening all together. No fuel in the oil, just a miss. Covered under warrantee.
Back to evening beverage of choice. . .
Old Sep 7, 2008 | 11:00 PM
ModManiac's Avatar
Ok guys I just checked my rail pressure, there is a 2030 psi difference at idle. I was thinking that if there was an injector issue then there would be no difference at rail pressure, so I believe it to be the FCA on the Cp-3. When you had injector issues did you check your rail pressure?
Old Sep 8, 2008 | 07:17 AM
FMB's Avatar
FMB
No, I didn't. The truck felt like it was running on 5 cylinders (because it was) and didn't think checking rail pressure would do anything to help diagnose the problem.
Old Sep 8, 2008 | 03:13 PM
ModManiac's Avatar
picking up a new fca today to see if it fixes the problem, if not ill let you guys know!
Old Sep 8, 2008 | 07:49 PM
georgboy's Avatar
Do you remember what the code was? My o5 is starting to have a slight puff in the mornings and feels like a small miss when warm. Thanks alot
Old Sep 8, 2008 | 08:55 PM
FMB's Avatar
FMB
If I remember correctly, P-2146 and P-0201. The CEL would set at WOT while getting on the Freeway. Not always, just sometimes at first, but just got worse and worse. Between the day I made the appointment at the dealer, and 2 or 3 days later, #1 stick quit altogether. It was almost 1k miles between first sign of the problem and repair.
For 'out of warrantee' work, I would seriously consider Don M's Formula 1 tips and repairing the bad injector. Look at http://www.f1diesel.com/injectorsecho.html and http://www.f1diesel.com/injectors24.html. I'll be considering the Mach 1.6 sticks.
Old Sep 8, 2008 | 09:38 PM
ModManiac's Avatar
Well i tried putting on the new fca this afternoon and the bottom torx screw got stripped Any recomendations on how to get it out??
Old Sep 9, 2008 | 01:47 PM
rip 112's Avatar
Easy out from Napa, but you gotta be really careful not to scour the fca mounting holes in the process.
i was gonna mention it may be a sticky fca, but looks like you've already thought of it.
Old Sep 15, 2008 | 12:41 PM
ModManiac's Avatar
I replaced the FCA and the truck idles smooth now and believe it or not I am not getting nearly as much timing rattle.
banks twinram
May 18, 2010 08:10 PM
Haulin_in_Dixie
Oct 23, 2005 10:04 PM
turbov6joe
Sep 25, 2003 10:57 AM
TheMoose
Sep 20, 2003 07:44 PM
Mexstan
Mar 31, 2003 02:37 PM
