Stuck Clutch
Old Sep 24, 2010 | 09:12 AM
paulmosh's Avatar
Stuck Clutch
I have an 03 3500 and have a problem with my trans/clutch. A couple months ago I replaced my clutch, pressure plate, and throwout bearing. A few days ago, while driving to work, the clutch would not disengage. I crawled under the track looking for possible clutch and/or slave cylinder leaks, but it all seemed to be in good shape (ie no leaks or physical damage). The clutch pedal still feels the same and i heard no noise or indications of bad throwout bearing.
Any guesses on what could be the problem?
Old Sep 24, 2010 | 10:38 AM
FMB's Avatar
FMB
Same guess as before. BTW, welcome to DTR.
Old Sep 24, 2010 | 11:29 AM
cbrahs's Avatar
more info will be needed like
stock clutch or aftermarket
any mods to the truck?
did you slip it (overheat it and weld the 2 pieces together)
welcome to dtr
Old Sep 25, 2010 | 10:15 AM
paulmosh's Avatar
Hey guys... changed out the clutch cylinder/slave cylinder assembly.... no luck.
The clutch is a stock unit
I have some +50hp injectors, but thats about it.
My trip to work is interstate and I really wasnt pushing the truck hard at all. It could have been slipping but if it was, it sure didnt seem like it.
When you say welded the two pieces together, what two pieces are you referring to?
Old Sep 25, 2010 | 11:32 AM
cbrahs's Avatar
pressure plate to disc.
Old Sep 25, 2010 | 12:52 PM
paulmosh's Avatar
stuck clutch
Thanks. I guess the only way to get to the bottom of this is to yank the trans back out......
birdboy
Dec 12, 2018 09:02 PM
birdboy
Apr 21, 2012 09:44 PM
Baja
Jan 29, 2008 08:17 PM
04ctd
Sep 14, 2004 04:43 PM
mysterync
May 31, 2004 11:11 AM
