Need C Code Explanation
Old Jan 11, 2014 | 04:29 PM
Calgary's Avatar
I have an '05 2500 Dsl. and was checking codes. I turned the key to on without starting while holding the trip reset. It did it's cluster check and gave me some C codes. However every time I did the procedure, I kept getting different codes....?
I am having a hard time getting info. about these codes. Can anyone help?
Codes that came up (and I only did it 4x) are:
A4 24
67 33
then
A4 22
67 31
then
A4 09
67 18
then
A4 26
67 35
Did a bit of checking and found that-from what I understand- code 67 could be from starting the truck with the drivers door open.
Not sure what A4 is.
BTW I did the key on/off/on x3 to check for codes and in only displayed "Done" so I assume I have no codes it that procedure.
I'm kinda confused.
Old Jan 11, 2014 | 05:52 PM
Dr.Dizzle's Avatar
I was informed that the digits and letters you noted are known as continuous codes related to functions of the vehicle and the instrument cluster. Two digits would report a condition and other digits would tell how many times it occurred. However, your ignition switch has 3 forward positions, accessory, on and start. To initiate the key trick you need to go ON off ON off ON (do not go to the start position, but you have to go past the accessory position) If you do this correctly, the codes will read out in the odometer. If the vehicle has no stored codes it should just say done followed by an audible (ding). Here is a listing of the C- codes for the 03 MY.
C-Codes
To obtain C-codes perform a Gauge Cluster Check: hold trip and turn key to run. Gauge lights will turn on to verify function, sweep gauges will move through sequence to very function, codes will display in ODO.
INSTRUMENT CLUSTER FAILURE MESSAGE
Fault Code Description
01 Airbag warning indicator output circuit shorted.
02 Airbag warning indicator output circuit open.
03 ABS indicator output circuit shorted. .
04 ABS indicator output circuit open.
05 MIL indicator output circuit shorted.
06 MIL indicator output circuit open.
07 Wait to start indicator circuit shorted.
08 Wait to start indicator circuit open.
0B BTSI output circuit shorted or open.
22 Headlamp switch input circuit shorted.
23 Headlamp switch input circuit open.
24 Turn hazard switch input circuit shorted.
25 Turn hazard swiitch inpot circuit open.
27 Courtesy/dome output circuit shorted or open.
28 Glovebox/map lamp output circuit shorted or open.
29 Cargo lamp output circuit shorted or open.
40 Wiper switch input circuit shorted.
41 Wiper switch input circuit open.
42 Wash/beam input circuit shorted.
60 Passenger door lock switch input circuit shorted.
61 Passenger door lock switch input circuit open.
62 Passenger door lock switch input circuit stuck.
63 Driver door lock switch input circuit shorte.
65 Driver door lock switch input circuit stuck.
66 All door lock output circuit shorted to ground or voltage.
67 All door unlock output circuit shorted to ground or voltage.
68 Driver door unlock output circuit shorted to ground or voltage.
6C Driver cylinder lock switch input circuit shorted.
6E Driver cylinder lock switch input circuit stuck.
80 Incorrect odometer value found. .
81 Remote radio switch input circuit high.
82 Remote radio switch stuck.
A0 Internal module FLASH memory checksum failure.
A1 Internal module bootloader failure.
A3 Battery voltage open.
A5 TCCM messages not received.
A7 VIN checksum error.
A8 VIN previously stored.
A9 PCI bus internal failure.
AA PCM messages not received.
AB TCM messages not received.
AC ABS messages not received.
AD FCM messages not received.
AE ACM messages not received.
AF SKIM messages not received.
B0 RKE fob batteries low.
B1 RKE module communication link.
00 Done All Diagnostic Trouble Codes (DTC) have been displayed.
Old Jan 18, 2014 | 11:13 AM
Calgary's Avatar
Smile C codes
Thanks, Dr.
Looks like the key may have been on when the doors were still open if I read the code 67 properly.
However there is no A4 in the list you gave me.
At any rate, I don't seem to have any "important" codes generated.
Thanks again.
Old Jan 18, 2014 | 02:24 PM
gcssr's Avatar
googled a4 sems to be gas engine =ignition mal.
HOHN
Mar 8, 2005 05:02 AM
wrk24wheel
Sep 23, 2004 11:15 PM
Pete Peterson
13
Jul 10, 2003 08:43 PM
thatguy
Oct 23, 2002 05:36 PM
