ac compressor not cycling on/off ice buildup
#31
None of those things will cause the compressor to run non stop, it seems like everyone is ignoring the facts and findings of trouble shooting......of course the evap will freeze up if the compressor never stops pumping refrigerant.
Find out what is keeping the clutch engaged with no call for AC.
#32
ac compressor fix??
Come on guys, focus. OP said compressor keeps running with AC turned off. It doesn't run with the fuse pulled. Low refrigerant will not make it run constantly, that will make it not run at all if everything is working correctly.
There is obviously a short from battery voltage to the clutch coil wiring somewhere. A schematic and someone that knows how to trouble shoot is needed at this point. Any further comments on this subject is purely conjecture.....
He did what you suggested and said that it does stop running. Plugged it in , then I got teased to death because IT SEEMS TO WORK FINE NOW. He asks,why were you saying it wasn't shutting off when climate button was off? Go look, I'm told. So I go look, sure enough he pushes the button it disengaged. I made him do it several times, as it was NOT turning off prior to then.. Drove on interstate and city traffic for 30 minutes, no ice buildup when I parked. Later drove 30 miles , again no issues. When you hit button now it does shut off, I had no loss of air flow while using it, and no frosted air coming out. I'll see what happens when I've driven an hour or more.
I thank you for your very sensible approach. I've got a transmission issue that I'm going to post a new thread for, hopefully see you there
Gypsy,
Much cooler now
Coaldigger
09-24-2008 03:05 PM
dodgemaniac
07-30-2008 09:30 PM
MRuskow
10-24-2007 11:31 AM
kawi600
06-04-2006 03:13 PM
