47RE case broken will 2005 48RE Trans work?
Old Feb 18, 2014 | 04:06 PM
Banzai Bob's Avatar
Started to rebuild and upgrade my 47RE from 2003 4x4. Rebuilder called and said the case was toast. I can't find a 47RE case anywhere but can get an 05 low mileage used 48RE trans at reasonable price. Has anyone any info on making this work. If I can, I am looking at simply installing this trans and making the rig work. If I have to rebuild the 48re with 47RE internals I may as well wait and see if I can find a case that works. Thanks very much for any info.
Old Feb 18, 2014 | 10:28 PM
jballou's Avatar
I think cases are the same, its the guts that are a bit different. Shouldnt your trans builder know the answer?
Old Feb 19, 2014 | 07:38 AM
Banzai Bob's Avatar
He has not retrofitted one before so he is nor sure of the TV cable/actuator situation. I figured if it has been done and works well, someone here will know. The cases will bolt up the same, guts/valve body different. I would rather find out what would work before I buy the 48RE, but then again don't want to miss out on the deal.
wyododge
Aug 18, 2011 07:48 AM
bowhunter57
Oct 28, 2009 11:10 AM
S/P G671
Sep 30, 2009 11:33 PM
RonD
May 10, 2007 11:06 AM
FireNhole
Dec 7, 2002 04:39 PM
