Why do I smell mildew when I turn on the A/C?
Old Jun 18, 2007 | 04:05 PM
JSPulliam21's Avatar
I put the heater hose on the evap drain last weekend. I will try the enema deal, too. I did not know about the vent position to help keep things dry, but I will start doing that. Does anyone know why the compressor cycles in the vent position?
Old Jun 18, 2007 | 04:36 PM
phox_mulder's Avatar
Shouldn't cycle in the vent only position.
It will cycle in floor/vent, defrost (and any variant of defrost) and any A/C position (of course).
The only ones it shouldn't cycle in are vent only, and floor only.
phox
Old Jun 18, 2007 | 10:06 PM
JDGnut's Avatar
As Phox said.. the only non compressor positions are the floor only and the upper vent only.. the Bi position runs the compressor..
I'd never even think about install the sealer in an AC systems.. Many places have had to buy testers to test for the stuff.. It can knock out a recovery/recycle machine in a heart beat.. Most of those sealers react to air.. (or moisture.) if you have a leak it seaps out contacts the air.. and hardens.. Ok.. so you fixed the leak... but Next time you open the system.. you got a real mess...
Use the dyes to find the leak.. and fix it.. You'll be happier... just adding some refigerant.. until you can fix it right..
Good Luck..
Bryan
Old Jun 19, 2007 | 12:42 AM
chuxtruk's Avatar
Good Luck..
Bryan
Hey, It's got a tiny hole in it anyway. I know it should be an R & R job but going through all of that in the pic of that dash hanging there by guide wires just doesn't somehow get me in the mood for THAT. I don't care what the sealer does to someone's machine as the only machine that's going on it is my neighbors a/c machine and that'll be before any sealant goes in there. In fact, he has to use the machine to see how large the hole is & if the sealer can even be used. If it can, and once sealed, I'll run it till it drops and THEN I'll fix the evaporator at my convenience by tossing it and installing a new one. Not because it's 90 degrees and I want cold air....who doesn't?? Sealer in the old evaporator?? Who cares!! It's basically junk anyway....
trailinone
Oct 20, 2010 12:26 PM
sgrooms
21
Apr 8, 2008 11:17 AM
shortbed rv
Jun 29, 2007 06:17 PM
Big Rig
33
Jan 20, 2006 04:11 AM
tacook
Sep 18, 2005 09:15 AM
