Turn Signals
Old Nov 11, 2006 | 04:13 PM
eric13's Avatar
Turn Signals
What would cause the turn signal indicator light in the dash to blink really fast?
Old Nov 11, 2006 | 05:15 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Check for a blown bulb.
Old Nov 11, 2006 | 06:03 PM
infidel's Avatar
They also blink fast if there is too much load such as a trailer or short to ground.
What I've run into a couple of times is a trailer jack full of dirt. When it gets wet it can short out. Not enough to blow the fuse but enough to make the signals blink fast.
Old Nov 11, 2006 | 06:18 PM
DodgeCowboy's Avatar
DTR's Cow Boss
I can remember which way it works fast or slow but i do know there is a different flasher for a heavy duty and there is standard. The standard will not work if you got a trailer hooked up but i cant recall if it blinks faster or slower.
Old Nov 11, 2006 | 06:46 PM
b4wheeler's Avatar
Heavy duty flashers flash faster than normal until a trailer is hooked up and the current load is increased. At this time, the flashing slows down to normal.
A fast flasher is the indication of a burnt out bulb, decreasing the load on the flasher and therefore flashing faster.
whazzup
Jun 21, 2004 06:44 AM
signature600
Apr 22, 2004 07:30 PM
Sky-dogg
Apr 5, 2004 02:26 PM
HitTheRoad
Jan 20, 2003 10:20 PM
boehunter49
Nov 28, 2002 06:41 PM
