Track Bar Issue
Old May 3, 2007 | 04:25 PM
Tileman1's Avatar
Track Bar Issue
Hey guys... I recently replaced my track bar trying to get rid of my death wobble issue. I few days ago, I hit a bump just right and WHAM! the DW returned. I had my friend turn the wheel back and forth with the key on and not running and noticed the axle end (passenger) bushing moving between 3/16" to almost 1/4" back and forth. Is this normal? I would hate to think something like a sleeve for the bushing was supposed to be reused in the new track bar.
Thanks in advance.
Old May 3, 2007 | 05:43 PM
wcbcruzer's Avatar
You can get a Lukeslink. $85 or so shipped with the end bushing. I got one, haven't installed it yet. But it's supposed to be good. www.lukeslink.com
Old May 3, 2007 | 05:56 PM
TheBigNasty's Avatar
It is a rubber bushing, so probably yes, it will have some movement. Hard to tell w/o looking at it. The DW is probably coming from other worn out pieces.
Old May 3, 2007 | 07:47 PM
slim51015's Avatar
You really have to wrench that bolt tight. I put mine on and a few months later the steering was wondering, I put an impact gun on the bolt, solved the problem.
Old May 3, 2007 | 08:29 PM
oldblues's Avatar
Question proper track bar torque ?
hi
does any one know what the factory torque speck is for the 2nd and 3 rd gen track bar is suppose to be ?
thank you !
Old May 3, 2007 | 08:51 PM
slim51015's Avatar
Originally Posted by oldblues
hi
thank you !
The bolt at the axle bracket is 130 ft.lbs.
The ball stud on 2nd gens is 70 ft. lbs.
Old May 4, 2007 | 02:34 PM
smokeyram's Avatar
you should not have that much play
mine after a ton of headache with death wobble, turned out the bold on the passenger side had ovaled out the hole.
I welded in plate, with the hole resized, been fine since,
Old May 4, 2007 | 07:18 PM
Tileman1's Avatar
thanks for the response guys... I'll check the torque in the AM...
Old May 5, 2007 | 10:43 PM
hink's Avatar
Don't Forget To Check Your Steering Stabilizer Also. That Can Cause A Serious Wobble Too. Just Pull One End Loose And See If You Can Feel A Good Amount Of Resistance When You Push It In And Pull It Out. If You Feel Little Or No Resistance, Then It's Time To Replace That Too.
Old May 6, 2007 | 08:37 AM
Tileman1's Avatar
Thanks for the input guys... I needed to tighten the axle side bolt a little, but not too much. The stabilizers look like they leaked and was going to change them. I have two of them, would I need the same part number or are they different? Many mentions in the forums in regard to the stabilizers refer to one in many cases. Does anybody else have two?
Old May 6, 2007 | 09:43 AM
XLR8R's Avatar
I don't think the steering stabilizer will cause - or solve - your DW issue.
Old May 7, 2007 | 12:30 AM
hink's Avatar
Code:
well apparently you've never had one go out on you before! what do you think the function of a steering STABILIZER is????????? anyway, if you have 2 str. stabilizers, then someone has probably put on an aftermarket kit. unless you are running larger tires you can replace it with a single kit and be alright. i usually didn't run a dual setup unless i was running 35" or taller tires. when (if) you replace it, if you want to go to a single, then make sure you get a kit so it will come with the brackets so you can change it out. unless you are just buying a replacement stabilizer they should come with a bracket kit, but check with the supplier to make sure.
Old May 7, 2007 | 02:41 AM
XLR8R's Avatar
I guess my trucks must have plenty of the "good" caster - because I haven't noticed any difference from the factory steering dampener.
However, the sector shaft stabilizer I made works VERY well:
Old May 7, 2007 | 05:50 AM
Tileman1's Avatar
I don't think it is an aftermarket setup. There are no unusual brackets installed and they appear to be stock units. One is attached on passenger side from the frame to the steering and the drivers side is mounted from the steering to the axle. Was this an option during my model year?
Old May 7, 2007 | 08:07 AM
atthepark's Avatar
Put a Lukes Link, new bushing and new steering damper and so far so good....no DW! Total less than $150.
Good luck.
