tires and shocks
Old Jan 5, 2008 | 10:42 AM
pwregan's Avatar
tires and shocks
time for tires and shocks for my second gen. i would like to get 3rd gen rims and tires but dont know if they will work- any input from the experts here will be appreciated
shocks- any opinions on the edelbrocks- i have them on my suburban and they were an improvment over the stocks-
thanks for all the help you guys provide!!
Old Jan 5, 2008 | 11:00 AM
displacedtexan's Avatar
The third gen rims will work.
Most on here will reccomend Bilsteens.
Old Jan 5, 2008 | 01:19 PM
afoulk's Avatar
I think the edelbrocks wouldn't be a bad choice, although maybe a little more expensive than others. My dad has them on his Ranger and they made a huge difference over stock. If you don't tow or haul much, I'd go with a D load range tire instead of E, they'll help your ride out a bit more too as the sidewalls are a little more forgiving. My buddy has the same suspension as me (other than cheapy rancho shocks) and it rides much better than mine with D range tires. I still have the E's on mine that came with it.
Old Jan 6, 2008 | 11:58 AM
sdsaw's Avatar
Correct me if I'm wrong, but I don't believe that Edelebrock has an AIS shock available for the diesel trucks (GVW-8800#) I already made that mistake with some Monroe Sensatracs that blew out pretty quickly on mine. Bilsteins seem to be the preferred shock for a smoother ride.
3rd gen rims work just fine on our trucks. You should try to find a set of aluminum ones over a steel set because the lug area is thicker and will give you more clearance for the center cap to pop on.
Call around to look for some factory take-off's if you don't mind the stock size tire(265-17) There are some great deals out there if you look.
Hope this helps.
Old Jan 6, 2008 | 11:23 PM
jcarew's Avatar
shocks
Hi I have Monroe Magnums for about 60k reasonably priced good service, very satisfied
Old Jan 6, 2008 | 11:24 PM
jcarew's Avatar
shocks
jcarew's Avatar
shocks
jcarew's Avatar
shocks
jcarew's Avatar
shocks
jcarew's Avatar
shocks
jcarew's Avatar
shocks
jcarew's Avatar
shocks
jcarew's Avatar
shocks
jcarew's Avatar
Smile shocks
jcarew's Avatar
Smile shocks
