Tires
Old Aug 7, 2013 | 07:17 PM
Funker's Avatar
Tires
Hello
Bought my 1st 3/4 ton, just had 1/2 tons before. I do realize 3/4 ton is heavier, was wondering what would be a good tire for it and size. I have a 99 dodge 2500 Cummings. I have 265/75/16 bfg all terrains on it.
Winter is around the corner need something to stick to the pavement.
thanks
Old Aug 7, 2013 | 11:21 PM
lovinCTD59's Avatar
I have good luck with my Yokohama Geolandar ATS when plowing deep heavy snow.. they spin a bit but always find something to grab onto.
PS.. *Cummins*
Old Aug 8, 2013 | 09:16 AM
patdaly's Avatar
I had terrible luck with my BFG's, so I now run Cooper Discoverer ST's. Really happy with mine in 235-85R16.
You want to make sure you get an E rated tire to utilized the carrying capacity of the truck, typically more expensive, and harder sidewalls, but needed if you carry significant weight.
I do know there are some D rated ones that have the capacity as well, but you are safe with all E rated tires.
Old Aug 8, 2013 | 10:42 AM
Midnite's Avatar
If you had 265/85-R16s on your '99, then the rims are too wide for 235/85-R16s. The 265s are the stock size, and you can stay with those if you're happy with them. I've tried 255/85-R16s and I'm currently running 285/75-R16s.
Generally I prefer the taller profile of the 85 series tires, but the 255/85s were barely wide enough for these stock aluminum rims. 265/85s would be better, but nobody makes that size.
Mike
Old Aug 9, 2013 | 12:30 AM
joem's Avatar
whatever you get, make sure they are load range E, zero budge and zero flex in high speed turns while carrying weight. Check this pict out with 2 yards of wet playground sand @ 4250 pounds
I love my cooper STT's
Old Aug 9, 2013 | 10:15 PM
taken5875's Avatar
I also run the cooper discover's I'm on my second set. 315/75/16 on a truck with leveling kit
chrisminx
14
Jul 7, 2010 06:48 PM
1320
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
Captain
Sep 9, 2005 12:16 AM
