Tire Information
Old Aug 2, 2006 | 09:26 AM
wadel1's Avatar
Tire Information
I have searched and not found an answer to my question so now I will post it here.....
On my stock '99 4x4 2500 CTD what size tires can I use on it....I would like to increase the size of what is there now...but I also dont want to deal with any issues with rubbing on anything. Assume I need E rated...
Also I need to know what type of tires people recommend....BFG, etc etc....
Thanks for your time!
Old Aug 2, 2006 | 09:49 AM
Viperdew's Avatar
I assume that you probably have 245 or 265/R70's now right? Without a lift you can run 285/R70's without any problems.
Old Aug 2, 2006 | 11:12 AM
displacedtexan's Avatar
I would reccomend 285/75/16. In the Cooper Discover S/T. They shouldn't rub at all. Mine didn't. And I flexed it a bit the 5 days I had them.
Old Aug 10, 2006 | 11:48 PM
Double A's Avatar
I had (until about 3 hours ago) 285/75/16 Trxxus mud-terrains on my stock 4x4 with no rub at all. I wouldnt recommend the tires, but the size and tread was fine.
Old Aug 11, 2006 | 05:53 AM
Lt.B's Avatar
I got the Michelin 285 16 LT tires on mine. no rub no problems. They were a little pricey but are an excellant choice. I put a pallet of stone pavers in that truck and aside form the squat youd never know they were there. Good strong sidewall. Ididnt feel any flex or sway when cornering. Same report for towing the boat. Even in soft sand at the beach they perform well. I dont even slack the tire pressure when on the beach. As long as I stay level It doesnt try to dig in. Most of my driving is on the street so I like the tread design, not real agressive so they are quiet.
Old Aug 11, 2006 | 05:55 AM
dodgeguy71's Avatar
Not sure about sizes, but you assumed correctly, E rated tires. I have the Firestone Wilderness AT's and have around 14,000 miles on them. No odd wear, cupping or anything, rotate them regularly, actually once. I have been pleased with them.
Old Aug 11, 2006 | 06:36 AM
JEMGTX's Avatar
I have two sets of LT 285/75/16. BFG's on 8" Alcoa wheels for the summer, and Kelly's on the stock wheels for the winter. The the front BFG's will "slightly" rub on a hard turn. This is not an even issue, I'm sure this is due to the off set of the Alcoa's. The Kelly's on the stock wheels are fine. I also have a 285/75/16 on the spare, and it fits even with the Mag-Hytec rear diff cover.
Old Aug 11, 2006 | 09:45 PM
Joe Mc's Avatar
I had a set of Coopers - 305/70/16s they were real nice looking and were OK until about 40k miles then they started acting funny hard to balance and . . . hard to explain. Then around 45k I noticed big time cracks between the lugs showing bands "scarry" - funny thing the tread was still fine? I was told by members on TDR that I was fortunate to get that many miles out of Coopers. I really liked them and tried to find another set (I think they were Discovery A/Ts) and was told they stopped making them. So I asked around and found that alot of guys liked the Nitto Terra Graplers. The guy who did my DTT (Tim Barber, Va. Beach) had them on his truck and spoke highly of them. So I did the 305's again, the Coopers were only load D the Nittos are E and are very quiet with very good manners. Oh I forgot to mention the 305 spare will fit in the stock location, a bit of finnessing is required but it fits - with a 1/2" between it and the 4" tail pipe. I gotta make a heat sheild one of these days. I got them on tires direct.com w/free shipping. I use dyna beads and "never" have any balance issues. Great tires - great beads - MHO
Old Aug 11, 2006 | 10:43 PM
bamadzl's Avatar
I run 295/75/16 Nittos and I've never had a rub. But these are D rated.
Brad
Old Aug 11, 2006 | 10:50 PM
That would be the problem. I have a lot of friends with PSDs that run the S/Ts to 50k a set. (2-3 seta apiece) I had them on my 99 for less than a week before it got stolen. I have run the A/Ts, and other Coopers before, and the S/Ts are the only ones I liked, and the only ones I have heard nothing but good out of. Also FWIW, two of the friends that run the Coopers switched from the BFG, and are not looking back.
Old Aug 11, 2006 | 11:29 PM
Mt Ram's Avatar
I for one wouldn't run ANYTHING from cooper! Try the Toyo M-55. They have good offroad traction and hold up very well even on gravel.
Old Aug 12, 2006 | 03:23 AM
Joe Mc's Avatar
Opps! Sorry I forgot to mention the 305s don't rub anywhere - comes close in the front, 1/4" from the mud flap and about 3/8 from the suspension but, dosen't rub.
Old Aug 12, 2006 | 11:12 AM
Can I ask why?
Old Aug 12, 2006 | 05:10 PM
greasemonki's Avatar
285/75r16 BF Goodrich A/Ts here. On stock rims, no rubbing what-so-ever. IMHO some of the best tires on the market, They are D rated, but if memory serves me they have the same weight rating as E rated from other manufacturers
Old Aug 14, 2006 | 11:43 PM
Mt Ram's Avatar
displacedtexan,
I've had bad luck with them. I don't like changing flat tires in the mud. I've had rocks shaped like a flattened egg go completely inside a cooper tire, and they wear out fast on gravel! These are my experiences with cooper tires, maybe others have done better than I have, but I wouldn't take a set of coopers for free!
